Topic: Trouble uploading analog serial read code (Read 191 times) previous topic - next topic
FocalFour
Oct 09, 2018, 08:40 pm Last Edit: Oct 10, 2018, 12:18 am by ballscrewbob
Hello,
I am currently using an Uno board with myoware attachment while running the analog serial read code for a project. I am experiencing trouble uploading the code to my board, it uploads once but will only plot points for a few seconds then it stops and wont restart unless the board is unplugged. I've copied my error message below. I have looked online for help as well as at other posts on this forum, however after trying a new board, clearing my computers ports, etc. I am still having this problem
Thanks!
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Code: [Select]
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Leila\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\Leila\AppData\Local\Temp\arduino_build_549129 -warnings=none -build-cache C:\Users\Leila\AppData\Local\Temp\arduino_cache_289114 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Leila\Documents\Arduino\sketch_sep25b\sketch_sep25b.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Leila\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\Leila\AppData\Local\Temp\arduino_build_549129 -warnings=none -build-cache C:\Users\Leila\AppData\Local\Temp\arduino_cache_289114 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Leila\Documents\Arduino\sketch_sep25b\sketch_sep25b.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129\sketch\sketch_sep25b.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129\sketch\sketch_sep25b.ino.cpp" -o "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129\sketch\sketch_sep25b.ino.cpp" -o "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129\sketch\sketch_sep25b.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129/sketch_sep25b.ino.elf" "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129\sketch\sketch_sep25b.ino.cpp.o" "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129/..\arduino_cache_289114\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\Leila\AppData\Local\Temp\arduino_build_549129" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129/sketch_sep25b.ino.elf" "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129/sketch_sep25b.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129/sketch_sep25b.ino.elf" "C:\Users\Leila\AppData\Local\Temp\arduino_build_549129/sketch_sep25b.ino.hex"
Sketch uses 2098 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 200 bytes (9%) of dynamic memory, leaving 1848 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Leila\AppData\Local\Temp\arduino_build_549129/sketch_sep25b.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
        Copyright (c) 2007-2014 Joerg Wunsch
        System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
        Using Port                    : COM3
        Using Programmer              : arduino
        Overriding Baud Rate          : 115200
An error occurred while uploading the sketch
avrdude: ser_open(): can't set com-state for "\\.\COM3"
avrdude done.
 Thank you.
ballscrewbob
Modified for clarity.
With NOTHING ELSE connected to the board can you use it normally to upload sample sketches such as BLINK etc. ?
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
hammy
It is uploading ok , but then stops after a while .
Do you have anything connected and powered by the Arduino ? That may over heat and shutdown the regulator , causing this problem.  If not that there is likely to be an error in the code .
