Topic: GCC compiler segmentation fault (?!) (Read 785 times) previous topic - next topic
aggrav8d
I didn't know I could do it.  Achievement get?
Code is latest dev branch of https://github.com/MarginallyClever/Makelangelo-firmware/
Arduino 1.8.7 64bit with all updates installed.
Windows 10.
Compiling for MEGA2560.
full error message(s):
Code: [Select]
C:\Users\Admin\Documents\GitHub\Makelangelo-firmware\motor.ino: In function 'setPenAngle':
C:\Users\Admin\Documents\GitHub\Makelangelo-firmware\motor.ino:278:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.15.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "SD.h"
 Used: C:\Users\Admin\Documents\Arduino\libraries\SD
 Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries\SD
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Dance as if no one is watching; post as if it is going to be read aloud as evidence in court.
pert
This bug is specific to the 5.4.0-atmel3.6.1-arduino2 version of avr-gcc used by Arduino AVR Boards 1.6.22 and newer. It has been reported here:
https://github.com/arduino/Arduino/issues/7949
Here's the workaround:
  • Tools > Board > Boards Manager
  • Wait for downloads to finish.
  • When you move the mouse pointer over "Arduino AVR Boards", you will see a "Select version" dropdown menu appear. Select "1.6.21".
  • Click "Install".
  • Wait for installation to finish.
  • Click "Close".
Due to a bug, this workaround doesn't work with Arduino IDE 1.8.6, but it will work with any other version of the Arduino IDE.
If you have File > Preferences > Check for updates on startup checked, the Arduino IDE may occasionally notify you that a new version of Arduino AVR Boards is available, you'll need to refrain from updating back to the new Arduino AVR Boards version, otherwise you'll be back to seeing the segmentation fault error again.
aggrav8d
You were helpful, thorough, fast, and correct!  Thank you - Kudos!
pert
You're welcome. I'm glad if I was able to be of assistance.
Regards, Per
