Topic: How to program to communicate between FTDI & Arduino? (Read 962 times) previous topic - next topic
reefat
I want to read the serial data transmitted by arduino on my computer using FTDI API (Visual C++).
Arduino uses Serial.print or Serial.write to send data to it's serial port. I am trying to capture this transmitted data on my computer using FTDI API.
Note: I have connected my Arduino to my computer using the FTDI breakout (from SparkFun).
Please see the following tutorial:
http://www.codeproject.com/KB/system/ftdi-chip.aspx
It worked until establishing connection to FTDI. But somehow I am getting reading error. My Arduino is using Serial.print to print 0..1.. ... ... 9 every 300ms. Meaning it prints 1 then after 300ms prints 2 and so on.
Any suggestion will be appreciated.
MikMo
Why are you using the FTDI API?
Your FTDI breakout from sparkfun will show up as a serial port on your computer.
You can use ordinary serial communication to talk to it.
reefat
I am trying to understand how arduino read/write or communicate to the ATmega chip. I'm building a custom MCU board. I will use the same technique there.
