Loading...
Pages: [1] 2   Go Down
Author Topic: 2 months with the same problem GPS give rubbish with Arduino Uno.  (Read 1699 times)
Offline Offline
Newbie
View Profile
Hello brave sparkies
I should better cut the long story short. So, I interfaced the GPS with the arduino Uno using the serial port (0, 1). my goal is to reveice data from GPS.
I wrote a few codes with the help of www.arduino.cc but I face the same problem at the end.
I do receive data but the problem is they are all rubbish. here is the code I used for the last one, which is not mine... I just copy from http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1280535694
#include <NewSoftSerial.h>
NewSoftSerial nss (0,1);
  nss.begin(57600);
  if(nss.available()) {
    Serial.print(nss.read(),BYTE);
What I received on the serial monitor is something close to ÆÑÙÝ-àÆÆÆ-ÉÎü,ÿÿÆÆññÆÆÆ
and bunches of different rubbish.
With the same GPS reciever I get this on the hyper terminal on the computer.
$GPGSV,1,1,01,09,00,000,20*43
$GPRMC,184045.000,V,0000.0000,N,00000.0000,E,000.0,000.0,010411,,,N*7F
$GPVTG,000.0,T,,M,000.0,N,000.0,K,N*02
$GPGGA,184046.000,0000.0000,N,00000.0000,E,0,00,0.0,0.0,M,0.0,M,,0000*62
$GPGSA,A,1,,,,,,,,,,,,,0.0,0.0,0.0*30
beside I have a second GPS receiver that behave exactly like the first one on the arduino UNO and on the hyper terminal (for those of you who has Window XP).
I investigated for quite sometime now (at least 2 months) and I think I do not have a clue of what do next anymore.
I tried to change the parity, stop bit and data lenght and different stuff with no avail.
at the end I suspected that the code I wrote was not correct so I used someone else code that worked (the one up there). it gives me exactly the same rubbish like any other algorithm.
from the troubleshooting I have done so far, I know for sure that the problem is from the microcontroller atmega328 (arduino). is it the programming? is it the parity, stop bit, data length?
can anyone provide me a code to set up the parity, stop bit and data lenght. I have done it but I am not certain that it was the right way.
should one point me in the right direction, it will be desperately appreciate.
Logged
Scotland
Offline Offline
God Member
Have you had your Arduino fix today?
View Profile
WWW
What port speed are you using on hyper terminal?
Logged
Drew.
(MyPCB MANUFACTURING SERVICE)
Duemilanove - UNO - Leonardo - Mega 1280 - Mega 2560 - Pro
& Way too many custom boards.
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
What hardware and configuration are you using to read from the receiver on the computer?
(A "serial port" designed to connect to the 9-pin connector on most PCs and USB/Serial converter modules is NOT suitable for connecting directly to Arduino.  You need an "rs232 level converter" or similar.)
(and I though the "standard" speed for GPS things was 4800bps.)
(either of those issues would cause pretty much exactly the symptoms you are seeing.)
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Quote
Everything except the baud rate....
It looks like it may be another 2 months before he checks back here for an answer.  Maybe he's checking the cross-posts.
Don
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Code:
That's your mistake.  You can't run NewSoftSerial AND hardware serial on the same two pins!
Pick two OTHER pins for NewSoftSerial.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Multiple cross-posts.
Another one for the blacklist
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Thank you for your answers...
I changed the port but I get exactly the same rubbish
Logged
Offline Offline
Newbie
View Profile
Spycathcer
The GPS receiver I use is defaulted to 9600. and can use the 115200 baud rate and some more. I checked the datasheet. so on the hyper terminal it was set on 9600.
Logged
Offline Offline
Newbie
View Profile
Hello Westfw
I am using the max232 with the GPS S1315R. the GPS work with 9600bps which I used on the hyper terminal. in fact when I connect to the hyper terminal it does not do through the arduino and the result is great. I get the format I want. but through the arduino it is just something else... pretty much nonsense....
since everything work well with the hyper terminal... the conclusion is that there is no problem with the connections.
Logged
Offline Offline
Newbie
View Profile
sorry to disappoint you, the baud rate was ok... during investigation that's the reason I have not mention it
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
These Google translations aren't great - could you maybe get someone who speaks English to help you?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Your symptom looks like a baud rate mismatch.
How does the GPS determine what baud rate to use?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Quote
Sounds more like the max232 is still in-circuit to me.
Maybe the OP will enlighten us.
Logged
Offline Offline
Newbie
View Profile
see below the code I normally use to do get the information from the GPS.
The way you guys mention about the baud rate I feel like Serial.begin(9600); is not enough of a initialisation of a baud rate...?
what else should I do then if it is the case?
the code is a bit different that the first one.
   lcd.begin(16, 4);
   pinMode(rxPin, INPUT);
if (Serial.available() > 0)
      // read the incoming data:
  incomingdata = Serial.read();
if (incomingdata)
  j = 0;
  dataRead[j] = incomingdata;  //  include each char read to the array
     dataRead[j+1] = '\0';
     Serial.print(dataRead[j]);
     j++;
  Serial.print("Not found \n");
Logged
Offline Offline
Newbie
View Profile
There is a small mistake of } on the last message I posted... pls disregard.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
