Topic: My Windows not work with arduino (Read 197 times) previous topic - next topic
m_veidemanis
At Uno board conect Windows 7 encountered problem  :
Arduino might be malicios software (Code 52) and cant install board.Help pls.
pert
m_veidemanis's picture (which is completely unrelated to the topic):
Did you get the software from the official download page?:
http://www.arduino.cc/en/Main/Software
ballscrewbob
#2
Oct 11, 2018, 12:53 pm Last Edit: Oct 11, 2018, 01:04 pm by ballscrewbob
Not sure what the picture has to do with your issue ?
Anyway down to your real issue.
If you downloaded the IDE from this site it should not be an issue with your antivirus / antimalware.
You should tell us which software is giving you that error but I suspect its a driver problem.
Are you using a REAL arduino or a clone ?
If it is a clone you may need a driver CH340/341 or CP2102
There are some sites out there that offer drivers but may offer nefarious things instead always make sure you get the OFFICIAL drivers for hardware.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
m_veidemanis
Yes, downloaded from original site, no error messages received in process. It works on wife's Mac (but I need it on my PC).
ballscrewbob
CLONE or REAL Arduino ?  PS. we dont care which it is as we dont judge LOL
m_veidemanis
Sorry, uploaded the wrong picture. The right one included now.
ballscrewbob
#6
Oct 11, 2018, 01:20 pm Last Edit: Oct 11, 2018, 01:20 pm by ballscrewbob
Ok I see what you have there now.
Two choices to get past that.
1. Turn off "Driver enforcement" (you can google that easy enough)
2. Try running the driver install as Administrator.  (Google "RUN AS ADMINISTRATOR")
One of those options should get you past the issue but if you use option one remember to turn driver enforcement back on afterwards.
If sounds like your install of windows was done nicely and with security in mind.
pert
So the problem is the driver signature. That seems strange because I'd expect the official Arduino Uno driver to be signed and not cause this problem.
ballscrewbob
#8
Oct 11, 2018, 01:26 pm Last Edit: Oct 11, 2018, 01:27 pm by ballscrewbob
Hi Per.
Some windows installations can still cause that error.
Not seen too often with a "stock" windows install but if it was done properly (by my standards LOL) for a relatively new computer user I tend to save myself call outs by adding a few extra tweaks.
Some OEM's, colleges, companies also lock things down a little too.
m_veidemanis
#9
Oct 11, 2018, 01:50 pm Last Edit: Oct 11, 2018, 01:51 pm by m_veidemanis
Tnx ballscrewbob.Solved.Working fine.
ballscrewbob
Nice to get an easy one before the caffeine kicks in.
Thanks.
