Loading...
Pages: [1]   Go Down
Author Topic: Global variable "not declared in this scope"  (Read 712 times)
Offline Offline
Newbie
View Profile
I'm only used to programming things in PHP, so I understand there are differences.  I don't understand why, no matter where I declare this variable, I keep getting the same errors.
My entire program so far is as follows:
Quote
int greenPin = 11;
int redPin = 10;
int switchPin = 9;
int lightState;
  pinMode(greenPin,OUTPUT);
  pinMode(redPin,OUTPUT);
  pinMode(switchPin,INPUT);
//int lightState;
int lightDisplay(lightState){
  switch (lightState)
    case 1:
    digitalWrite(greenPin,HIGH);
    digitalWrite(redPin,LOW);
    case 2:
    digitalWrite(redPin,HIGH);
    digitalWrite(greenPin,LOW);
    case 3:
  if (digitalRead(switchPin) == HIGH)
    lightDisplay(3);
    lightDisplay(1);
All I want to do is be able to call the lightDisplay() function and tell it whether to light a green LED, a red LED, or nothing at all.  Seems like this would be easier than rewriting the digitalWrite() statements over and over.
Anyway, when clicking the Verify button, I get this:
sketch_apr01a:-1: error: 'lightState' was not declared in this scope
sketch_apr01a:12: error: redefinition of 'int lightDisplay'
sketch_apr01a:-1: error: 'int lightDisplay' previously defined here
lightState is declared at the top of the code so I don't understand how this can be happening.  Am I using the wrong datatype or something?
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
Does lightState have a type?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Seattle, WA
Offline Offline
God Member
View Profile
WWW
You can get rid of it at the top of your code.  You just need to 'declare' it in your function definition
Code:
void lightDisplay(int lightState){
And make it a void function because it returns nothing.
Logged
Offline Offline
Newbie
View Profile
Thank you.  I'm not used to having to declare variables that way, so no wonder I couldn't figure it out.  Declaring the variable inside the function worked great.
Logged
Georgina Ontario
Offline Offline
Sr. Member
Arduino rocks
View Profile
There is a reference section for this idea of scoping!
http://www.arduino.cc/en/Reference/Scope
It is worth the time to read and understand.
Global variables should generally be avoided.
Local variables are better.
Except for the exceptions -- but that is the advanced class.
Logged
Just another Hacker
Pages: [1]   Go Up
Print
Jump to:
