Topic: I'm confused with my motors (Read 510 times) previous topic - next topic
Yovan10
I'm doing my robot.I have done everything right.
I have attached my circuit below
This is my code:
Code: [Select]
const byte enA = 9;//defining the pins for usage
const byte in1 = 4;
const byte in2 = 5;
const byte enB = 11;
const byte in3 = 6;
const byte in4 = 7;
int val = 0;//The Values recieved by the Bluetooth is assigned to this variable
int starttime = 0;//For running a command for desired secs
int endtime = 0;//        ""
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  //Read input from bluetooth module:
  if ( Serial.available())
    val = Serial.read();
  //Input key switch
  switch (val) {
    case '0':
      analogWrite(enA, 0);//controls speed
      analogWrite(enB, 0);
      //Code when no key is pressed
    case '1':
      // Set Motor A Forward
      digitalWrite(in1, LOW);
      digitalWrite(in2, HIGH);
      // Set Motor B Forward
      digitalWrite(in3, LOW);
      digitalWrite(in4, HIGH);
      starttime = millis();
      endtime = starttime;
      while ((endtime - starttime) <= 3000) // do this loop for up to 1000mS
        // code here
        analogWrite(enA, 250);
        analogWrite(enB, 250);
        Serial.println("<Forward>");
        endtime = millis();
      //Code when DOWN key is pressed
    case '2':
      // Set Motor A backward
      digitalWrite(in1, HIGH);
      digitalWrite(in2, LOW);
      // Set Motor B backward
      digitalWrite(in3, HIGH);
      digitalWrite(in4, LOW);
        // code here
        Serial.println("<Backward>");
        endtime = millis();
    case '3':
        // code here
          analogWrite(enA, 200);
          analogWrite(enB, 200);
          Serial.println("<Left>");
        endtime = millis();
      //Code when LEFT key is pressed
    case '4':
      //Code when RIGHT key is pressed
        // code here
          Serial.println("<Right>");
        endtime = millis();
      Serial.println("<right>");
    case '5':
      //Code when X key is pressed
      while ((endtime - starttime) <= 1000) // do this loop for up to 1000mS
        // code here
          Serial.println("<Drift left>");
        endtime = millis();
    case '6':
        // code here
          Serial.println("<Drift right>");
        endtime = millis();
      //Code when O key is pressed
    default:
        // code here
        endtime = millis();
      // default code (should never run)
The problem is that One of my motors run both sides and another that is the motor connected to my OUT 3 and 4 Does'nt run forward
I'm supplying a voltage of 18V(2 9V batteries)
What could be wrong?
pls help me
Delta_G
OP's picture fixed so you can see it.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Yovan10
Pls tell me what could be the reason
groundFungus
Quote
Are the 9V batteries those small rectangular ones made for smoke alarms?  Your diagram shows 12V.
Yovan10
Yeah you are right.
Also suggest me another way, my battery gets drained faster.
how to save power in the circuit
jremington
9V block batteries are totally unsuitable for motors.
A 6xAA battery pack should work, at least for a while.
groundFungus
You need batteries (or other power supply) that can deliver the motor's rated voltage to the motors and the stall current of the motors (X2 current  if both motors are to start at once).  There is no way around that.  9V transistor batteries will never supply enough current.
If you are concerned with saving power, get rid of that L298 and get a proper modern motor driver.
If you want help to choose a driver, please supply a data sheet for the motors.
Yovan10
Can you tell me a way to give separate power supply to the motors and separate to the others
Thanks Bro for the help
Yovan10
Should I use 12 AA(each 1.5V) batteries for the power supply???
or 6AA is enough??
pls answer me bro... :)  :)
jremington
Quote
Yovan10
I don't know what's a datasheet pls explain me bro...:(:(
What can I do with it.
Pls help me in this regard
groundFungus
A data sheet for a part is where you find detailed specifications for the part.  Do you know the part number of the motor?   If not, post any numbers written on the motor and we can try to find a data sheet.  We need to know the motor's rated voltage and the stall current.
Yovan10
The Motors Rated Voltage is 5V-9V
I have a number written on it.
2016301077161
I don't what this means but This is only number on it
Thanks for the reply
ChrisTenone
Where did you get the motors, where did you find the circuit? Show a picture of the motors if you found them in a basket at your front door. Folks need to know more about your specific hardware if you want them to help you design your robot.
ps, just for good measure, don't say "pls", say "please", and not so often. And don't call us bro. We aren't your brother, nor are we in a 1973 crime drama.
What, I need to say something else too?
Delta_G
Quote
+1.  People are volunteering to help you for free.  Please show them at least a little respect and speak like you have a little bit of education and care at least a little.
|| | ||| | || | ||  ~Woodstock
