Topic: Problem reading pointer to PROGMEM int variable with pgm_read_word (Read 197 times) previous topic - next topic
Flatomic
Hello:
I am trying to get the INT value stored in the program memory through pgm_read_word. But mySerial.printf() shows 0 instead 85.
What is wrong with my code?
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(1, 0);
PROGMEM const int num = 85;
const int *pointer;
  mySerial.begin(9600);
  pointer = &num;
  int *x = (int*)pgm_read_word(&pointer);
  mySerial.println(*x);
PaulS
Why are you casting the int returned by pgm_read_word() to an int pointer?
westfw
Quote
Code: [Select]
You're reading FROM a pointer, not TO a pointer.  (unless you want the word from address 85 of RAM.)
and "pointer" is already a pointer, so you don't need the "&" in front of it.
So that should just be:
Code: [Select]
      int x = pgm_read_word(pointer);
// Or:
      int x = pgm_read_word(&num);
Flatomic
¡Yes! It is unnecesary. pgm_read_word return an 16bit unsigned integer. Furthermore I don't need '&' symbol on
Code: [Select]
Now, this is my code, and it returns the correct value!
Code: [Select]
PROGMEM const int num = 69;
const int *pointer;
     pointer = &num;
     mySerial.println(x);  // Print
Thanks!!
Flatomic
I have a new problem if I try to reading a PROGREM struct...
Code: [Select]
typedef struct MenuItem {
 const char *name;
 const int *quantity;
} MenuItem;
// Menu Item values
PROGMEM const char name[] = "NAME";
// Initialize menuitems
PROGMEM const MenuItem mi = {name,&num};
const MenuItem *root;
 // Pointer to menuitem struct
 root = &mi;
 // Get the name
 char buf[50];
 strcpy_P(buf, (char *)pgm_read_word(&root->name));
 // Get the quantity
 int q = pgm_read_word(&root->quantity);
 mySerial.println(buf);  // Prints: NAME
 mySerial.println(q);  // Prints 104. It's incorrect!
stowite
Code: [Select]
 PROGMEM const char *name;
 PROGMEM const int *quantity;
} MenuItem;
This will solve your immediate problem but why are you storing a pointer to an 'int' in PROGMEM rather than just the 'int' value.
Flatomic
Code: [Select]
} MenuItem;
Sorry, but this doesn't work. With your modifications mySerial prints incorrect values:
Code: [Select]
mySerial.println(buf);  // Print: ö
mySerial.println(q);  // Print 250. It's incorrect!
To your question: I need this INT pointer to point to a variable that constantly changes. This code that I have published is a reduced version of a larger one. In the larger one, I have a menu with menu items. Every menu item has a "name" and a "quantity".
Then I combine this values to show texts like "5 Notifications", where name="Notifications" and quantity="5".
Quantity is the pointer who points to notificationsCount.
This is the code with your modifications:
Code: [Select]
} MenuItem;
// Menu Item values
  root = &mi;
  // Get the name
  char buf[50];
  // Get the quantity
  mySerial.println(buf);  // Print: ö.  It's incorrect!
  mySerial.println(q);  // Print 256. It's incorrect!
