Topic: Help: Row Scanning Multiplexing RGB Led (Read 75 times) previous topic - next topic
jaspal23
Oct 12, 2018, 01:56 pm Last Edit: Oct 12, 2018, 01:57 pm by jaspal23
I am trying to make a some patterns which run on 6 RGB Leds (Common Anode). I uploaded the circuit diagram. I have also written code but it is not a worth it. I need help on creating some patterns like 6 Leds get on with red colour then change into green and finally blue color with some interval.
please guide me, how to make code efficient and optimized.
In diagram 4 transistors are used but now i am using 3 transistors (only 6 Leds)
Code: [Select]
const int row[4] = {12,8,7};   // Arduino row pins
const int column[6] = {11,10,9,6,5,3};   // Arduino column pins
for (int i = 0;i<3; i++)
    pinMode(row[i], OUTPUT);
    digitalWrite(row[i],HIGH);
for (int j = 0;j<6; j++)
    pinMode(column[j], OUTPUT);
    digitalWrite(column[j], HIGH);
analogWrite(11,255);
analogWrite(10,0);
analogWrite(9,255);
digitalWrite(12,LOW);
digitalWrite(12,HIGH);
digitalWrite(8,LOW);
digitalWrite(8,HIGH);
digitalWrite(7,LOW);
digitalWrite(7,HIGH);
Thanks is advance.
groundFungus
#1
Oct 12, 2018, 02:54 pm Last Edit: Oct 12, 2018, 02:55 pm by groundFungus
Code: [Select]
That section of code executes so fast that it will look like nothing is happening.  Insert delay()s between the digitalWrite highs and digitalWrite lows.
Better yet learn to use millis() (and micros()) for timing.  A beginner's guide to millis().
