Topic: By mistake, I applied 12 volts to ATMega8 microcontroller. Did it get damaged? (Read 177 times) previous topic - next topic
prabhu_metgud
Today, while doing a project on a breadboard, I accidentally connected 12 volts DC power supply to Ground pin of ATMega8 micro controller. Does this particular micro controller get damaged/malfunction because of this ?
spycatcher2k
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
rpt007
Quote
1. Could you check if it still works? If it was working before, but "after" not - it was damaged.
2. If you didn't check yet - it depends on the potentials on your Arduino and if or how the 12V DC was connected with BOTH pins. So: what about the GND of your 12V source - did you connect 12V plus/minus converted?
If GND wasn't connected at all to your device - nothing should have happened.
Means: we need more information to answer your question.
Before you ask:
Did you really read and understand How to use this forum ?
AND:
Do you have already some solution or is a part of the problem sitting in front of the screen?  :)
