Loading...
Pages: [1] 2   Go Down
Author Topic: [SOLVED]Serial input affecting a delay  (Read 909 times)
UK
Offline Offline
Newbie
wewt
View Profile
Hey guys. Im a bit perplexed! Im trying to set the rate of blinking of an LED (in an optocoupler) by reading what comes through the serial port. Here is my code;
Code:
#define OPTO 13 // optocoupler pin
int val =0; // variable to store the serial
int pause =0; // variable for our blinks
void setup(){
 Serial.begin(300);
 pinMode (OPTO, OUTPUT);
void loop (){
 while (Serial.available() ==0 ); // Arduino waits to recieve data
 int val = Serial.read()-('0'); // only reads the first byte of data
 int pause = map (val,0,9, 15, 100); // hence maximum of 9
  pause = constrain (pause , 15, 100);
 digitalWrite(OPTO, HIGH);
 delay(pause);
 digitalWrite (OPTO, LOW);
 delay(pause);
   Serial.println (pause);
The problem is that it only blinks the LED at the specified rate once, and then the serial goes back to 0.
Any help would be smashing thanks!
« Last Edit: April 03, 2011, 05:22:39 am by gravebond » Logged
Left Coast, USA
Offline Offline
Sr. Member
Sometimes I just can't help myself.
View Profile
... perplexed!..
Step away from Arduino for a minute and think about what you need to do.  Sometimes I actually write it out (on the back of a cocktail napkin at the NAME OF WATERING HOLE DELETED).
Often I write it in pseudo-code rather than my native language (American-English, as it happens.)  The point is that I try to express it in logical terms before I actually write code.
 (Instead of scanning the booze-stained napkin from this particular session at the lounge, I'll post my take on it as text):
The loop() function is executed repeatedly:
BEGIN loop function
    IF there is a character available THEN
        Read the character and calculate the "pause" value
    END IF
    Turn on LED
    pause
    Turn off LED
    pause
END loop function
Now if that makes sense, compare with your code.  If it doesn't make sense, ask again.
Regards,
Dave
« Last Edit: April 02, 2011, 04:05:28 pm by davekw7x » Logged
UK
Offline Offline
Newbie
wewt
View Profile
Sound sound advice indeed. Still though i am having trouble. Here's what i tried;
Code:
void setup(){
 Serial.begin(300);
void loop (){
  if (Serial.available() > 0) {
 delay(pause);
 delay(pause);
its still doing the same thing. Halp...
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
It isn't doing the same thing.
You have two "pause" - get rid of the local one.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
UK
Offline Offline
Newbie
wewt
View Profile
What do you mean by local one?
If i get rid of my "pause" int i cant map new values onto the single serial character i am getting.
Logged
UK
Offline Offline
Newbie
wewt
View Profile
i see now its just printing 0 constantly regardless of my typing into the serial moniter
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Code:
You had (always had)two variables called "pause".
Check scope rules.
http://www.arduino.cc/en/Reference/Scope
« Last Edit: April 02, 2011, 04:30:38 pm by AWOL » Logged
UK
Offline Offline
Newbie
wewt
View Profile
Ive now uploaded this and at least the serial moniter is making more sense now. However the Led is still not behaving.
Code:
void setup(){
void loop (){
  if (Serial.available() >0 ) {
  Serial.flush();
 delay(pause);
 delay(pause);
The led just flashes once, do need to make a seperate void and call it with an if?
Logged
UK
Offline Offline
Newbie
wewt
View Profile
Right ive got it working by adding a do.. while statement.
Code:
void setup(){
void loop (){
  Serial.flush();
  do
 delay(pause);
 delay(pause);// check the sensors
} while (Serial.available() ==0 );
However i dont think this is what you guys were getting at, so if theres a much more economic way of achieving the same results i would appreciate any insight. There is also some odd behaviour... When i input into the serial monitor, i have to input the number i want twice before the arduino changes the value of "pause". any ideas?
« Last Edit: April 02, 2011, 05:09:29 pm by gravebond » Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
The economic way was described in reply #1 = I can't see why it wouldn't work.
Why did you reintroduce the "while" loop?
It isn't needed.
« Last Edit: April 02, 2011, 05:15:39 pm by AWOL » Logged
UK
Offline Offline
Newbie
wewt
View Profile
i couldnt get it to work the way described in reply # 1. I was clutching at straws when i added the while loop, and it happened to work. Although it does look very clumsy. Could you explicitly tell me the code involved to make it work as described in reply #1 as i may have made a silly mistake somewhere when i tried my implementation of it?
« Last Edit: April 02, 2011, 05:21:57 pm by gravebond » Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
[uncompiled, untested]
Code:
int pause; // variable for our blinks
void loop ()
    int val = Serial.read(); // only reads the first byte of data
    pause = map (val, '0', '9', 15, 100); // hence maximum of 9
    pause = constrain (pause , 15, 100); // only needed if you don't get '0' to '9'
  delay(pause);
Logged
UK
Offline Offline
Newbie
wewt
View Profile
RIght that works, and was in fact the second thing i tried, the problem was declaring pause as an int in the map function in the loop. Thanks for the halp!.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
You might want to modify this code to properly deal with invalid input. Suppose the serial port is sent a 'B'. That is not in the range '0' to '9'. As written, the code will cause pause to be assigned either 15 or 100, depending on which invalid character is sent.
I'd prefer to simply ignore any invalid characters. Your mileage may vary.
Logged
UK
Offline Offline
Newbie
wewt
View Profile
Whats the most economical way of doing this? I dont want to have to make a separate if statement for number 1 -9. Another constrain on the val?
Logged
Pages: [1] 2   Go Up
Print
Jump to:
