Topic: [SOLVED]Serial input affecting a delay (Read 2867 times) previous topic - next topic
AWOL
You could test to see if the character is in the range '0' to '9' with a pair of comparisons.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
gravebond
if( val > =0 && val =< 9) ?
AWOL
Almost.
The characters coming in are ASCII, so:
if( val >= '0' && val =< '9')
gravebond
if( val >= '0' && val  =<'9'){
  digitalWrite(OPTO, HIGH);
  delay(pause);
  digitalWrite (OPTO, LOW);
  delay(pause);
  Serial.println (pause);
gets an error : expected - primary expression before '<' token
AWOL
gravebond
i think it was a copy and paste thing as well cos when i switched them around it threw up another error, but after retyping it, its compiled. Problem now is , it stops the function if you type in an erroneous char and the led stops its blinking.
gravebond
Tried a couple of else statements that arent working the way i wish.
I basically want a function to say
"Else , ignore and proceed as usual ...."
AWOL
Code: [Select]
void loop ()
  if (Serial.available() >0 ) {
    int val = Serial.read(); // only reads the first byte of data
    if (val >= '0' && val <= '9') {
      pause = map (val, '0', '9', 15, 100);
    //invalid character, ignite smoke bombs, sound klaxons
  delay(pause);
  delay(pause);// check the sensors
gravebond
Code: [Select]
#define OPTO 13 // optocoupler pin
int pause; // variable for our blinks
//we havnt declared val here as we only want it referenced inside our
//"if (Serial.available() >0 ) {" function.
pinMode (OPTO, OUTPUT);
void loop ()
     if (val >= '0' && val <= '9') { // Checks for any eroneous chars
   Serial.println ("Invalid!"); // prints invalid if you type something other
    }                          // than 0-9
  delay(pause);
Working. Might i say that you sir are cryptic... hepful yes... cryptic ....yes.
Thanks very much :D
PaulS
Quote
What more do you need than working code? Often, when we post code fragments the idea is the give the poster the information about what command to use, in the expectation that the reference pages will be used to check the exact syntax, as well as learn more about the command.
gravebond
Quote
Consider me learned! cheers folks
