Topic: HM10 Pairing Failed (Read 167 times) previous topic - next topic
Marcjericho
my hm10 bluetooth cannot connect on android when trying to pair it says "pairing failed incorrect pairing key or the device you want to pair with is configured incorrectly". PLEASE HELP im using huawei nova 2i android version 8.0.0
zachgreen2018
You need to use better punctuation, and write correct sentences. Maybe then you will get an answer.
You should also be as informative as you can.
Did you try 1234 and/or 0000 as the PIN?
-Zach
Nick_Pyner
#2
Oct 18, 2018, 01:32 am Last Edit: Oct 18, 2018, 01:36 am by Nick_Pyner
I assume English is your second language, but this is the bit that counts
It probably won't help, and the real answer is throw it away and get an HC-05, but note that pairing key is six digits and default is "000000"
zachgreen2018
Here is a link to a bluetooth hc-06, the pairing code should be 1234
https://www.banggood.com/HC-06-Wireless-Bluetooth-Transceiver-RF-Main-Module-Serial-For-Arduino-p-80364.html?rmmds=search&cur_warehouse=CN
-Zach
Nick_Pyner
I don't know why you would post that. it just confuses people.
