Topic: Add regulated 5v input pin to homemade arduino uno (Read 245 times) previous topic - next topic
Hltlnd112
Recently i've made my own Arduino Uno (atmega328p-pu). I've followed the tutorial on the arduino playground, but the problem is that i can only power it trough a power regulator.
That only allows it to be powered with 7-12 volts, but i want an option to power it with the 5v output of another Arduino uno (the Uno as ISP); that's why i need a regulated 5v input pin.
Does anybody know how to do it? Thanks in advance.
CrossRoads
sterretje
If the output of the other power source is regulated, you don't need to regulate the input.
The 5V output of an Uno is regulated, either via its voltage regulator or from the USB.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
DrAzzy
Schottky diode from usb-5v to 5v rail, and external 5v power to 5v rail directly.
Easypeasy.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Hltlnd112
So all i need to do is putting a diode between the 5v rail and the output pin on the regulator. Than i can just connect the regulated 5v directly to the 5v rail...
Thanks for the responses.
