Topic: Servo example not uploading/problem (Read 1 time) previous topic - next topic
ServoTech
I am trying to control a simple servo. I am going off this site to help me http://www.azega.com/arduino-servo-motor-part-1/ and I have it wired up just like in the picture. I am using the code from File>Examples>Servo>Sweep  I haven't modified the code at all. It compiles successfully but when I try to upload this shows up-
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Anyone know what the problem is and how I can fix it?
Any replies will be well appreciated, Thank You. Here's the code if anyone need to look at it.
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
spycatcher2k
disconnect usb - unhook servo - plug in usb - upload sketch - unhook usb - hook up servo - plug in usb
If this does not work its not a servo issue, let us know what happens.
Drew.
Drew.
http://www.uk-pcb.co.uk - My UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details.
retrolefty
Quote
That is an upload error, nothing to do with the sketch or the servo. That error means the Arduino IDE can't communicate with the board. Can you upload anything, like the simple blink example? Some common causes for that error are:
Not selecting proper comm port number in the arduino IDE
Not selecting the proper board type in the Arduino IDE
Not installing the PC USB serial driver software properly
Lefty
spycatcher2k
or its a faulty servo pulling loads of current from the arduino. Been there myself  :smiley-eek:
Drew.
retrolefty
Yes, could be. That's why I asked if he had ever uploaded blink succesfully. If so he could just unwire the servo and see if he can then upload OK or not. We will just have to wait for his response(s).
Lefty
ServoTech
I've tried this and the upload error continued to show up.
I also tried uploading the simple blink example and the error still proceeded.
So next I think I should try the options below. How do I know if I've done them correctly or done them at all? and if No how do I?
Quote
Thank You for all your responses! I am destine to figure this out!
retrolefty
http://arduino.cc/en/Guide/Troubleshooting
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
