Topic: VoIP support (terminal for Asterisk) (Read 15695 times) previous topic - next topic
ogogon
Is there an Arduino to support VoIP protocols and codecs?
I want to make a network VoIP gateway with additional options. Can I use for this purpose Arduino with ethernet board?
Ogogon.
ogogon
#1
Apr 04, 2011, 11:17 am Last Edit: Apr 04, 2011, 11:20 am by ogogon Reason: 1
Google says:
http://blog.makezine.com/archive/2010/09/outbound-calling-with-arduino-aster.html
Dear Richard!
If you go on the URL http://www.nerdybynature.com/index.php/2010/09/br-r-r-r-r-ing-its-your-arduino/, then we can read the description of the project.
He does not pass through a network of sound. It transmits only the signal of an event.
Ogogon (Richard, RU3DSH)
P.S. You might be interested. I'm trying to find easily upgradeable VoIP gateway or to make it. I want to pass through the signaling protocol SIP (exact SDP) commands to control a simplex radio.
73! RU3DSH (Richard de Chernogolovka, Moscow district)
ogogon
Can you suggest some inexpensive and well-documented platform for such development?
It is desirable that are running Linux ...
Ogogon.
tubular
Google says:
Dear Richard!
Has anyone else gotten this to work? It doesnt compile for me
* Asterisk Controlling Arduino Example
* A basic example displaying the ability of Asterisk
* open-source PBX to control an LED on an Arduino with
* an ethernet shield.
* Dan Wagoner
* http://www.nerdybynature.com
#include <Ethernet.h>
int LEDpin = 4;       //LED set to pin 4
int x;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //must give WIZnet a MAC
byte ip[] = { 192, 168, 15, 15 };       //must configure WIZnet IP
Sserver = Server(23);       //TCP port the server is listening on
            //I'm using telnet, but you could use any
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.begin(9600);       //for troubleshooting purposes (not needed)
  pinMode(LEDpin, OUTPUT);
void loop () {
Client client = server.available();      //client connects to server
I get "cannot allocate an object of abstract type 'Server'" right here
if (client){      //if connection present
  x = client.read();      //read information coming from server
  Serial.println(x);}      //print to serial (troublshooting only)
if (x == 0){      //if information sent is a zero
  digitalWrite(LEDpin, LOW);}      //turn of LED
else if (x == 1){            //if information sent is a one
  digitalWrite(LEDpin, HIGH);}      //turn on LED
else if (x == 2){            //if information sent is a two
  digitalWrite(LEDpin, HIGH);      //blink the LED
  delay(500);}
sonnyyu
#4
Feb 24, 2013, 06:21 am Last Edit: Feb 24, 2013, 06:23 am by sonnyyu Reason: 1
You might use Raspberry Pi as Ethernet shield, and load Asterisk at Raspberry Pi, and connect between Raspberry Pi and Arduino via usb cable.
Asterisk support;-
AGI (Asterisk Gateway Interface)
IVR (Interactive Voice Response)
TTS (Text-to-Speech, a lot of languages supported)
say Arduino has relay and temperature sensor, the person could call the Asterisk phone number,  go through IVR, get temperature via TTS, and switch on/off relay.
or  Arduino  push temperature reading to Asterisk AGI, and once AGI preset temperature reached, it will generate call.file and trigger asterisk make outbound call to play back prerecord sound or TTS voice.
Arduino+Asterisk could do much more, a little list here.
tubular
ya I have both a pi and arduino with ethernet shield, I would actually rather use the pi since its cost is less than a arduino+ethernet shield. Im trying to make it so than when an extension is dialed it would trigger a relay which would than unlock an electronic lock. So maybe I need to just get it working with a standalone pi, there are plenty of sip applications that can be installed on the pi but I would need to figure out how to make them run a script when a call is received
sonnyyu
#6
Feb 26, 2013, 07:34 am Last Edit: Feb 26, 2013, 07:52 am by sonnyyu Reason: 1
Arduino code:
 Physical Pixel
An example of using the Arduino board to receive data from the
computer.  In this case, the Arduino boards turns on an LED when
it receives the character 'H', and turns off the LED when it
receives the character 'L'.
The data can be sent from the Arduino serial monitor, or another
program like Processing (see code below), Flash (via a serial-net
proxy), PD, or Max/MSP.
The circuit:
* LED connected from digital pin 13 to ground
created 2006
by David A. Mellis
modified 30 Aug 2011
by Tom Igoe and Scott Fitzgerald
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/PhysicalPixel
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
 // initialize serial communication:
 // initialize the LED pin as an output:
 pinMode(ledPin, OUTPUT);
 // see if there's incoming serial data:
 if (Serial.available() > 0) {
   // read the oldest byte in the serial buffer:
   incomingByte = Serial.read();
   // if it's a capital H (ASCII 72), turn on the LED:
   if (incomingByte == 'H') {
     digitalWrite(ledPin, HIGH);
   // if it's an L (ASCII 76) turn off the LED:
   if (incomingByte == 'L') {
     digitalWrite(ledPin, LOW);
Asterisk  code:
/etc/asterisk/extensions.conf
[general]
static=yes
writeprotect=no
[default]
exten => 1001,1,Answer()
exten => 1001,n,Dial(SIP/1001,20,tr)
exten => 1001,n,Hangup
exten => 1688,1,NoOp()
exten => 1688,n,AGI(ledon.php)
exten => 1688,n,Hangup
exten => 1689,1,NoOp()
exten => 1689,n,AGI(ledoff.php)
exten => 1689,n,Hangup
/etc/asterisk/sip.conf
[general]
context = default
bindport = 5060
bindaddr = 0.0.0.0
tcpbindaddr = 0.0.0.0
tcpenable = yes
[1001]
type = friend
callerid = User One <1001>
secret = 1001
host = dynamic
canreinvite = no
dtmfmode = rfc2833
mailbox = 1001
disallow = all
allow = ulaw
transport = udp
Asterisk AGI code
ledon.php
#!/usr/bin/php -q
<?php $c stream_context_create(array('dio' =>
array('data_rate' => 9600,
  'data_bits' => 8,
  'stop_bits' => 1,
  'parity' => 0,
  'flow_control' => 0,
  'is_blocking' => 0,
  'canonical' => 1))); // Open the port $handle =
$handle fopen("dio.serial:///dev/ttyACM0""r+"false$c);
if (
$handle) {
//echo "Initiate port";
fwrite($handle'H');
fclose($handle);
exit(
0);
ledoff.php
#!/usr/bin/php -q
  'data_bits' => 8,
  'stop_bits' => 1,
  'parity' => 0,
  'is_blocking' => 0,
if (
$handle) {
fwrite($handle'L');
fclose($handle);
exit(
0);
put all AGI file into "/var/lib/asterisk/agi-bin/",  Asterisk  is need  compile at target machine and it does not support well with parallel build on multi CPU or cross compile for ARM processor. the long coffee break is needed for waiting compile finished.
dio.serial is php dio extension
install as:
apt-get install -y php5-dev php-pear
pecl install channel://pecl.php.net/dio-0.0.7
tubular
thanks sonny
only problem is Im not sure if a serial connection to the arduino from the box running asterisk is possible due to distance requirements. Any ideas for ethernet?
sonnyyu
arduino+ ethernet  shield  is ok.
ledon.php
#!/usr/bin/php -q
<?php
file_get_contents
(arduinoledonurl);
exit(
0);
sonnyyu
Add:
allow_url_fopen=1
in your php.ini file.
there are 2 php.ini  file at debian.
/etc/php5/apache2/php.ini
/etc/php5/cli/php.ini
since AGI is cli, add it into /etc/php5/cli/php.ini.
