Topic: How to use 4x4 membrane keypad with 16channel multiplexer? (Read 759 times) previous topic - next topic
samuelgregorovic
Oct 22, 2018, 05:31 pm Last Edit: Oct 22, 2018, 06:04 pm by samuelgregorovic
I´m working on an Arduino project, and i have ran out of usable pins.To put it simple, i need to find a way to use traditional 4x4 membrane keyboard through 16-channel multiplexor 74HC4067. So far, i searched along the internet but have not found any solution at all. Thank you for any hints. Here is what i have, i need this to be changed for use with multiplexor. i can process everything afterwards, i just cant get the keypad work over the multiplexor. It works when i connect it directly to arduino pins.  I tried a lot of things but no luck.  This code works when i connect the keypad directly to arduino.
Code: [Select]
/*4x4 Matrix Keypad connected to Arduino
This code prints the key pressed on the keypad to the serial port*/
#include <Keypad.h>
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {9,8,7,6}; //Rows 0 to 3
byte colPins[numCols]= {5,4,3,2}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
char getPin(char array[]){
  int possition=0;
  while(possition < 8 ){
    char keypressed = myKeypad.getKey();
    if (keypressed != NO_KEY ){
         if(keypressed>47 && keypressed<58){
            Serial.print("*"); //prints * on LCD (for every press)
            array[possition]=keypressed; //saves char to array
            possition++;
  return* array;
void loop(){
    char PUK[8];
    getPin(PUK);
    Serial.print("Entered PIN is: ");
    for(int a=0;a<8;a++){
        Serial.print(PUK[a]);
PaulRB
I don't think 74hc4067 is going to be much help. You would need 8 Arduino pins to read the keypad directly. With the multiplexer, you can reduce that to... 7 pins. 4 for keypad column selection, 2 for controlling the multiplexer to select a keypad row and one to read the multiplexer output. Maybe there is a better way, but I can't think of one at the moment.
I would recommend a pcf8574 chip. You need to free up the SDA & SCL pins (A4 & A5 on Uno/Nano).
Tell us what other components you want to connect and we can advise how to use fewer pins. I will take a guess that one of the components is a 16x2 LCD display, using 6 or 7 pins?
DrAzzy
You can't, because you need to monitor 4 pins, while keeping the other 4 pulled up, then when you get a signal, you know the row - then manipulate the other 4 pins while watching the one that changed in order to see which column (or vise versa). A 16-1 multiplexer only allows you to manipulate one pin at a time (and takes 5 pins to use!)
You can do it with a 8-bit port expander (and control said port expander with just the two I2C pins), though.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
samuelgregorovic
Thanks for replies, even though it is not ideal, i need to use it this way. I can´t use I2C pins, so is there ANY way to acomplish this using this multiplexer?
PaulRB
Yes, you can do it like I explained before. You will need 7 Arduino pins.
Or you make a keypad from 16 separate buttons. Then, using the multiplexer, you will need only 5 Arduino pins.
Or use your 4x4 keypad and two 74hc4067. You will need 5 Arduino pins.
Grumpy_Mike
Quote
That implies you have pins free but you can not use them. Do you know the analogue input pins can be used for digital I/O?
samuelgregorovic
#7
Oct 23, 2018, 09:21 am Last Edit: Oct 23, 2018, 09:23 am by samuelgregorovic
This is what i use:
                 I2C 16x2 LCD( SCL and SDA pins + GND + VCC)
                 MFRC522 RFID Card Reader(5 pins+GND+VCC)
                 4x4 Keypad(8pins)
I also need to use microSD card reader using 4 pins(CS,SCK,MOSI,MISO+GND+VCC)
and a classic servo motor and 2 RGB leds . Do you have any ideas how to pack all of this in one arduino UNO? GND and VCC are of course not a problem, i can use a  breadboard to solve that.
samuelgregorovic
can you help me with it? I understand how multiplexor works, i just dont really get how to use this piece of code anywhere in my program(not in this loop()), and how to talk to these channels. thank you
Code: [Select]
#include "MUX74HC4067.h"
#include <Keypad.h>
 LiquidCrystal_I2C lcd(0x27,16,2);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keymap[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
MUX74HC4067 mux(7, 8, 9, 10, 11);
byte rowPins[4] = ???????
  byte colPins[4]= ???????
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, ROWS, COLS);
void setup(){
   lcd.init();
      lcd.begin(16,2);
      lcd.backlight();
      lcd.setCursor(0,0);
    mux.signalPin(3, INPUT, DIGITAL);
     lcd.setCursor(0,0);
void loop(){
  lcd.print(keypressed);
Paul__B
This is what i use:
                 4x4 Keypad(8pins)
So you are already using the I2C bus for a "backpack" which uses a PCF8574 chip, so your "I can´t use I2C pins" is in fact, total nonsense!  :smiley-eek:
That means you can use another seven PCF8574 port expander chips (they come on modules ready to use, just like the LCD backpack) for anything you want - you could read seven 4 by 4 matrix keyboards if you needed to with no trouble at all.  :smiley-roll:
I don't think we need waste our time with any further suggestions about "alternatives".
