Topic: Sending data buffer through serial, some values get shifted (Read 748 times) previous topic - next topic
dberezin
I'm working on a project were I have to send data through serial and I figured out filling a buffer was the best option. So far, I'm puting the values of a lookup table I'm using to output a wave through the DAC and sending those values through serial. The problem is that a few wave periods get sent correctly but then some others get shifted (each value gets multiplied by 256) and then the problem fixes itself. But of course, I need the data to be sent trustfully.
const PROGMEM short sintab[3][512] = ... //lookup tables
int wave = 1;
int i = 0;
int k = 1;
short* buff;
const int buflen = 1048;
void setup(void) {
  buff =  new short(buflen);
  Serial3.begin(57600, SERIAL_8E2);
void loop(void) {
    i+= k;
    j++;
    if (i>511){
      i-=512;
    if (j>buflen){
      byte* bytePointer =(byte*)buff;
      for (int l=0; l<buflen; l++){
        Serial3.write(bytePointer[l]);
        Serial3.flush();
      j = 0;
      delete(buff);
There are the relevant chunks of code. The lookup tables go from 0 to 4095, hence I use short (most significant bit should always be zero). But on the other side, checking with a serial monitor, higher values get received. I tried puting down the baudrate, adding parity and stop bits and allocating memory with the new command (before I was just declaring the buffer as an array). The whole code is attached. Any ideas on how to send the right values and no other is well received.
ard_newbie
To print a 2 dimension buffer, you can do that:
const uint16_t bufsize = 512;
uint16_t buf[4][bufsize];
  Serial.begin(250000);
  // Fill buf[][]
  static uint8_t bufn;
  printArray(buf[bufn]);
  bufn = (bufn + 1) % 4;
void printArray(uint16_t x[])
  for (int i = 0; i < bufsize; i++) {
    Serial.println (x[i]);
For ADC sampling and DAC output, here is an example sketch:
/*                  ADC and DAC in FREE Running Mode and PDC DMA                           */
volatile uint32_t Timestamp, Oldmicros;
volatile boolean Flag, Flag_dac;
volatile uint8_t bufn, bufn_dac;
const uint16_t bufsize = 128;            // size must be a power of 2
const uint8_t bufnumber = 4;             // bufnumber > 2, better be a power of 2
const uint8_t _bufnumber = bufnumber - 1;
uint16_t buf[bufnumber][bufsize];        // bufnumber buffers of bufsize samples,
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(12, OUTPUT);
  adc_setup();
  dac_setup();
  Oldmicros = micros();
  if (Flag) {
    Flag = false;
    Serial.println(Timestamp);
/*************  Configure adc_setup function  *******************/
void adc_setup() {
  PMC->PMC_PCER1 |= PMC_PCER1_PID37;                    // ADC power ON
  ADC->ADC_CR = ADC_CR_SWRST;                           // Reset ADC
  ADC->ADC_MR |=  ADC_MR_TRGEN_DIS                      // Free Running Mode selected
                  | ADC_MR_FREERUN
                  | ADC_MR_PRESCAL(1);                  // Or PRESCAL (1) to reduce ADC frequency to 21 MHz
  ADC->ADC_ACR = ADC_ACR_IBCTL(0b01);                   // For frequencies > 500 KHz
  ADC->ADC_IER = ADC_IER_ENDRX;                         // End Of Conversion interrupt enable for channel 7
  NVIC_EnableIRQ(ADC_IRQn);                             // Enable ADC interrupt
  ADC->ADC_CHER = ADC_CHER_CH7;                         // Enable Channel 7 = A0
  /*********  code for PDC/DMA  buffer filling sequence **********/
  ADC->ADC_RPR = (uint32_t)buf[1];                      // DMA buffer - First one will be buf[1]
  ADC->ADC_RCR = bufsize;
  ADC->ADC_RNPR = (uint32_t)buf[2];                     // next DMA buffer
  ADC->ADC_RNCR = bufsize;
  bufn = 2;
  ADC->ADC_PTCR |= ADC_PTCR_RXTEN;                      // Enable PDC Receiver channel request
  ADC->ADC_CR = ADC_CR_START;
/*********  Call back function for ADC and DACC PDC/DMA **************/
void ADC_Handler () {
  bufn = (bufn + 1) & _bufnumber;
  ADC->ADC_RNPR = (uint32_t)buf[bufn];
  Flag_dac = true;
  bufn_dac = (bufn_dac + 1) & _bufnumber;
  DACC->DACC_TNPR = (uint32_t)buf[bufn_dac];
  DACC->DACC_TNCR = bufsize;
  // For debugging only
  static uint32_t Count;
  if (Count++ == 7812) { //1000000/128 ~7812
    Timestamp = micros() - Oldmicros;
    Flag = true;
    Count = 0;
    PIOB->PIO_ODSR ^= PIO_ODSR_P27;  // Toggle LED_BUILTIN every 1 Hz
void dac_setup ()
  PMC->PMC_PCER1 = PMC_PCER1_PID38;                   // DACC power ON
  DACC->DACC_CR = DACC_CR_SWRST ;                     // Reset DACC
  DACC->DACC_MR = DACC_MR_TRGEN_DIS                   // Free Running Mode selected
                  | DACC_MR_USER_SEL_CHANNEL1         // select channel 1
                  | DACC_MR_REFRESH (1)
                  | DACC_MR_STARTUP_8
                  | DACC_MR_MAXS;
  DACC->DACC_ACR = DACC_ACR_IBCTLCH0(0b10)
                   | DACC_ACR_IBCTLCH1(0b10)
                   | DACC_ACR_IBCTLDACCORE(0b01);
  DACC->DACC_IER = DACC_IER_ENDTX;
  NVIC_EnableIRQ(DACC_IRQn);                          // Enable DACC interrupt
  DACC->DACC_CHER = DACC_CHER_CH1;                    // enable channel 1 = DAC1
  /*************   configure PDC/DMA  for DAC *******************/
  DACC->DACC_TPR  = (uint32_t)buf[0];                 // DMA buffer
  DACC->DACC_TCR  = bufsize;
  DACC->DACC_TNPR = (uint32_t)buf[1];                 // next DMA buffer
  bufn_dac = 1;
  DACC->DACC_PTCR = DACC_PTCR_TXTEN;                  // Enable PDC Transmit channel request
void DACC_Handler() {
  if (Flag_dac) {
    Flag_dac = false;
      Count = 0;
      PIOD->PIO_ODSR ^= PIO_ODSR_P8;  // Toggle pin 12 every 1 Hz
