Topic: switch... case 0, 2, 4, 6, 8: (Read 4984 times) previous topic - next topic
pedroferrer
Good morning
I would like to know if is possible to do the following or near?
switch (MenuActual){
     case 0, 2, 4, 6, 8:
           //do something
     case 1, 3, 5, 7, 9:
           //do something
Thanks on advance
Best regards
Pedro Ferrer
Si
No, I think you can only have value.
If this is exactly what you want to do then,
if (menuActual % 2)
 // do even stuff
 // do odd stuff
I write books about Arduino and Electronics: http://simonmonk.org
pedroferrer
Thanks Si
On VB I can have it...
Select Case MenuActual
           Case 0, 2, 4, 6, 8
                    //do something
           Case 1, 3, 5, 7, 9
                    //do something
End Select
Thanks on advance
Best regards
Pedro Ferrer
Si
Sadly, thats one nice feature of VB that is not in C.
You'll probably end up using ifs and else ifs.
webmeister
Try this:
switch (MenuActual)
    case 0:
     do1();
     break;
    case 2:
     do1();
     break;
    case 1:
     do2();
     break;
    case 3:
     do2();
     break;
pedroferrer
Good morning
Thanks Webmeister.
Is what I have at the moment.
I've just thought that exist a better way to do it...
It seems that unfortunately... not
Thanks to you all
Best regards
Pedro Ferrer
Groove
    case 0:
    case 2:
    case 4:
    case 6:
    case 8:
          //do something
          break;
Per Arduino ad Astra
pedroferrer
Good morning
Groove, please explain me:
    case 0:
    case 2:
    case 4:
    case 6:
    case 8:
          //do something (action 1)
          break;
    case 1:
    case 3:
    case 5:
    case 7:
    case 9:
          //do something (action 2)
          break;
It will work?
Thanks on advance
Best regards
Pedro Ferrer
Groove
Yes, it will work.
Any "case" that doesn't have "break" will fall-through to the next case.
pedroferrer
Thanks.
I'll try later at night.
Thanks once again
Best regards
Pedro Ferrer
pedroferrer
What's up deSilva?
Best regards
Pedro Ferrer
mpeuser
Difficult to say...
Why is C/C++ so primitive?
Why took it so long you got a good answer?
Why couldn't you find out yourself?
Oh, forget it! I'm sometimes in this mood....
Groove
#13
Sep 16, 2010, 01:21 pm Last Edit: Sep 16, 2010, 01:24 pm by GrooveFlotilla Reason: 1
What's up deSilva?
I just think s/he's trying to bump her/his post count.
If you think of C (or C++) as a high-level assembly language (which is what C was designed as), you won't ever make the mistake of thinking it "primitive".
westfw
if (c & 1) {
  // c is odd
 // c is even
Or perhaps:
if (c >= 0) && (c <=9) {
 if (c % 2) {
   // c is even
   // c is odd
