Topic: Enclosure for arduino etc (Read 883 times) previous topic - next topic
buteman
Hi all,
I have ordered a Uno, rtc and LCD display so I can get on with my project.
Once I get it all up and running I am thinking about how I would set it up
as a permanent unit ( might use one of the simpler boards for this ).
As a standalone unit I would either add a keypad or use a PS2 keyboard.
Anyone got ideas on how I could make a decent looking job of putting
it all in a case - LCD, keypad etc? I am in the U.K
Norman
Si
When I make an Arduino project permanent, I generally take the microcontroller off the Arduino board and put it on stripboard with a crystal. Its really not that hard. I do this in 2 steps, first putting everything on breadboard and then transferring the breadboard to stripboard when I know everything is woking.
I'm not the tidiest person when it comes to boxing, but I tend to use an ABS box and cut the holes using a Dremmel-type circular cutter at low speed to stop the plastic melting too much.
I write books about Arduino and Electronics: http://simonmonk.org
liuzengqiang
Some uses lunch boxes or cardboard boxes. I've used cardboard boxes, acrylic face plates, and better ones.
Here is my little journey FYI:
http://liudr.wordpress.com/2011/01/10/make-an-enclosure-or-face-plate-for-your-arduino-projects/
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
