Topic: [SOLVED] Keypad number input and store (Read 19809 times) previous topic - next topic
Gudas
Apr 05, 2011, 03:52 pm Last Edit: Apr 05, 2011, 09:31 pm by Gudas Reason: 1
Hi.
I'm a beginner with Arduino programming and need some advice. My project is a bit bigger, but I'm stuck right now on this (quite simple?) problem.
What I need is read numbers that are typed on o 4x3 keypad, then store them in a variable and put on LCD display. The variables are three, and for each one the user can enter values. My code looks somtehing like this (the setup part is not shown):
Quote
 // for 12V -----------------------------------------------------------
 char key1 = kpd.getKey();
 switch (key1) {
   case NO_KEY:
   case '0': case '1': case '2': case '3': case '4':
   case '5': case '6': case '7': case '8': case '9':
   lcd.print(key1);
       firstvariable = firstvariable* 10 + key1 - '0';
   case '#':
       Serial.println ();
   Serial.print ("Value for 12V is: ");
   Serial.print (firstvariable );
   case '*':
       firstvariable = 0;
       lcd.clear();
       Serial.println ();
   Serial.print ("Reset value:");
 // for 12V end -----------------------------------------------------------
This is only for the first value. What I need is when the user press #, the firstvalue is stored, and the program continues on the input of the second value. After the second value, it continues with the input of the last (third) value.
I've tried doing some functions and calling it after the # button press, but with no luck. Can someone please give me a hint, how should it look like?
Thank you.
PaulS
You need to keep track of whether the keypad input is for the first variable, the second variable, or the third variable. The easiest way to do this is to put the code you have in a function that returns an int.
Code: [Select]
int GetNumber()
   int num = 0;
   switch (key1)
     case NO_KEY:
      lcd.print(key1);
      num = num * 10 + (key1 - '0');
    case '#':
        return num;
    case '*':
        num = 0;
        lcd.clear();
Then call the function as required:
Code: [Select]
   v1 = GetNumber();
   // Do something with v1
   v2 = GetNumber();
   // Do something with v2
   v3 = GetNumber();
   // Do something with v3
Gudas
Thank you.
I've tried that code, but I must doing something wrong (dunno what). To me, it looks like the program never 'waits' for the # button to pass the stored number out of the called function.
When I read the output in the function, it gives me only zero, whatever is pressed. And when the output is read in void loop, there is only a constatn flow of zeroes.
What I need to do is count the numbers in one variable until # is pressed, then the program should continue the same way for the second variable etc. After that the code will work with the inserted numbers...
Code: [Select]
#include <Keypad.h>
#include <LCD4Bit_mod.h>
LCD4Bit_mod lcd = LCD4Bit_mod(2);
int v1 = 0;
int v2 = 0;
int v3 = 0;
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = { 22, 23, 24, 25 };
byte colPins[COLS] = { 26, 27, 28 };
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  lcd.init();
  lcd.commandWrite(0x0F);
  lcd.clear();
   v1 = GetNumber();
   //Serial.println ();
   //Serial.print (v1);
   v2 = GetNumber();
   v3 = GetNumber();
int GetNumber()
   int num = 0;
   char key = kpd.getKey();
   switch (key)
     case NO_KEY:
      lcd.print(key);
      num = num * 10 + (key - '0');
    case '#':
//Serial.print (num);
        return num;
    case '*':
        num = 0;
        lcd.clear();
[/size]
Sorry if I ask dumb questions, and thanks for patience  :)
PaulS
Sorry. There needs to be a while loop in the GetNumber function. Something like this:
Code: [Select]
int GetNumber()
   int num = 0;
   while(key != '#')
      switch (key)
         case NO_KEY:
            lcd.print(key);
         case '*':
            num = 0;
            lcd.clear();
      key = kpd.getKey();
   return num;
Gudas
Excellent! Now its working fine.
Many thanks  :)
patrixx
in this part
Code: [Select]
why its reduced by zero?
PaulS
Quote
The value of '5' as a number is 5. The value of '7' as a number is 7. The value of '0' as a number is 0.
So, subtracting '0' from a character representing a digit results in the digit that the character represents.
odometer
Actually, each of these characters has two values: the one that we want, and the one that is used internally by the software.
As far as the software is concerned:
the value of the character '0' is the number 48;
the value of the character '1' is the number 49;
the value of the character '2' is the number 50; and so forth.
But (as I'm sure you know) those aren't the values we want!
So we subtract 48 from each of these values to get the values we want.
The value of the character '0' is the number 48, but we want the number 0, so we subtract 48 from 48 to get 0.
The value of the character '1' is the number 49, but we want the number 1, so we subtract 48 from 49 to get 1.
The value of the character '2' is the number 50, but we want the number 2, so we subtract 48 from 50 to get 2.
And so forth.
For more characters, please see this link: https://www.cs.cmu.edu/~pattis/15-1XX/common/handouts/ascii.html
patrixx
sorry i comment on an old post,,
when i tried pauls code, if i type more than 5 character the value become negative. how to solve this?
when i press 111111 it become -19961
PaulS
Quote
Don't store the value in an int. Use a long.
art_a_game
Sorry to comment in this older post but I also encountered having negative values when I entered a 5-digit number. I have tried what pauls said to change int into long but still I get negative values. Hope you can read this and help me with my problem
odometer
Please post your code.
hici
hello everyone.
I'm trying to use this code as it is posted by PaulS only with a different lcd library:
Code: [Select]
#include <Keypad.h>
#include <Wire.h>
#include <LCD.h>
LiquidCrystal_I2C  lcd(0x27, 2, 1, 0, 4, 5, 6, 7);
int kdelay = 50;
int period = 0;
const byte COLS = 4;
char hexaKeys[COLS][ROWS] =
  { '1','4','7','*' },
  { '2','5','8','0' },
  { '3','6','9','#' },
  { 'A','B','C','D' }
byte rowPins[ROWS] = { 5, 4, 3, 2 };
byte colPins[COLS] = { 9, 8, 7, 6 };
Keypad kpd = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
int v1 = 0;
int v2 = 0;
  lcd.begin(20, 4);
  lcd.setBacklightPin(3, POSITIVE);
  lcd.setBacklight(HIGH);
   v1 = GetNumber();
   v2 = GetNumber();
int GetNumber()
   int num = 0;
   while(key != '#')
      switch (key)
         case NO_KEY:
            lcd.print(key);
            num = num + key;
         case '*':
            num = 0;
            lcd.clear();
      key = kpd.getKey();
   return num;
My problem is that when I press the # button nothing happens. Everything else works. The numbers are printed on the LCD and the * button clears the LCD but.
Thanks in advance for the help
PaulS
Quote
What are you expecting to happen? Add Serial.print() statements at the top and bottom of GetNumber(), and you'll see that something is happening.
hici
yeah right I didn't know what I was thinking there thanks for that. I also had the negative number problem and solved it by using a string instead of an int and then converting it with toInt(). I think it should work for the others as well.
here it is:
Code: [Select]
String v1;
String v2;
  lcd.begin(20, 4);
   v1 = GetNumber();
   v1.toInt();
   Serial.println(v1);
   lcd.clear();
//   v2 = GetNumber();
//   Serial.println(v2);
String GetNumber()
   String num;
   while(key != '#')
      switch (key)
         case NO_KEY:
            lcd.print(key);
            num = num +key;
         case '*':
            num = "";
            lcd.clear();
      key = kpd.getKey();
   return num;
