Topic: One button control of multi state switch - CODE (Read 4374 times) previous topic - next topic
tburt11
I am developing a sketch that will allow me to control my swamp cooler based on temperature, time of day and manual override.
Here is some code I have written (and tested) that controls the cooler with one button.
Some criteria I have included:
1 button to switch between 5 states (hi/lo speed with & without water pump plus off)
A delay so that the cooler does not switch with every button push, but instead, wait until I have finished pushing buttons to set the new cooler state.
Feedback on the cooler state with 3 LED's (Hi, Lo, Water)
The ability to set any cooler state by sending a char from the host computer via the serial line (USB)
There are several situations where this code/logic could come in handy..
Enjoy
Quote
#define swampon 4
#define swamphi 5
#define swampwa 6
#define button 7
#define redled 8
#define yelled 9
#define grnled 10
#define rlydly 500
int buttonState = LOW;
int coostat = 0;
// 0 -> Off
// 1 -> Low Air
// 2 -> Hi Air
// 3 -> Low Cool
// 4 -> Hi Cool
  pinMode(swampon, OUTPUT);
  pinMode(swamphi, OUTPUT);
  pinMode(swampwa, OUTPUT);
  pinMode(button, INPUT);
  pinMode(redled, OUTPUT);
  pinMode(grnled, OUTPUT);
  pinMode(yelled, OUTPUT);
  if (chkbuttonpress()) {
    coostat = coostat + 1;
    if ( coostat == 5 ) coostat = 0;
    setcooled(coostat);
    for (int i = 0 ; i < 800 ; i++) {
      delay(1);
        if (coostat == 5) coostat = 0;
        setcooled(coostat);
        i = 0;
    setcooler(coostat);
  if (Serial.available() > 0) {
    char incomingByte = Serial.read();
    int myByte = int(incomingByte)-48;
    if (myByte >= 0 && myByte <= 4){
      setcooled(myByte);
      setcooler(myByte);
int chkbuttonpress() {
  int gothigh = 0;
  for (int cc = 0; cc < 6; cc++){
    delay(1);
    buttonState = digitalRead(button);
    if (buttonState == HIGH){
      gothigh = 1;
    } else {
      if (gothigh == 1){
        return HIGH;
      } else {
        return LOW;
  return LOW;
void setcooled(int newsetting) {
  // All Off
  digitalWrite(redled,LOW);
  digitalWrite(grnled,LOW);
  digitalWrite(yelled,LOW);
  switch(newsetting){
    case 0:
    case 1:
      ledon(redled);
    case 2:
      ledon(yelled);
      ledon(redled);
    case 3:
      ledon(grnled);
      ledon(redled);
    case 4:
      ledon(grnled);
      ledon(yelled);
      ledon(redled);
void setcooler(int newsetting) {
  // All Off
  digitalWrite(swampon,LOW);
  digitalWrite(swamphi,LOW);
  digitalWrite(swampwa,LOW);
  switch(newsetting){
    case 0:
    case 1:
      setpin(swampon);
    case 2:
      setpin(swamphi);
      setpin(swampon);
    case 3:
      setpin(swampwa);
      setpin(swampon);
    case 4:
      setpin(swampwa);
      setpin(swamphi);
      setpin(swampon);
void setpin(int pin) {
  digitalWrite(pin,HIGH);
  delay(rlydly);
void ledon(int num){
  digitalWrite(num, HIGH);
void ledoff(int num){
  digitalWrite(num, LOW);
robtillaart
Thanks, nice job.
You could improve your code by using an enum - http://www.arduino.cc/playground/Code/Enum
The code will not change much except it becomes more readable, look at the snippet below
e.g.
Code: [Select]
enum COOSTATE { OFF, LOW_AIR, HIGH_AIR. LOW_COOL, HIGH_COOL };
COOSTATE state;
void setcooled(COOSTATE newsetting) {
  // All Off
  switch(newsetting)
    case OFF:
    case LOW_AIR:
        ledon(redled);
    case HIGH_AIR:
        ledon(yelled);
        ledon(redled);
    case LOW_COOL:
        ledon(grnled);
        ledon(redled);
    case HIGH_COOL:
        ledon(grnled);
        ledon(yelled);
        ledon(redled);
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
