Loading...
Pages: [1]   Go Down
Author Topic: Arduino temperature&presence sensor with web page and SNMP  (Read 1907 times)
Verona (VR)
Offline Offline
Newbie
New Arduino Player...
View Profile
Hi, we are develop a project with arduino for monitor temperature and presence. We have to reach the state by web and with SNMP polling, also save some data in a SD card.
We use Arduino Uno + Eth Shield (SD), an analog thermistor and one PIR.
The task are:
  • client webpage build on arduino showing the temperature and if there's a precence
  • write on SD card when is disclose a presence
  • response to SNMP request with the temperature state and other some parameter
The sketch seem to work fine, but it crash a lot of time, and we doesn't know if is a memory problem, or other software issue.
Have someone find other similar problem and could help us?
Logged
Verona (VR)
Offline Offline
Newbie
View Profile
This is part of our code:
Code:
#include <Streaming.h>         // Include the Streaming library
#include <Ethernet.h>          // Include the Ethernet library
#include <Flash.h>
#include <SPI.h>
#include <MemoryFree.h>
#include <Agentuino.h>
#include <SD.h>
#include <Time.h>
#include <Udp.h>
  Ethernet.begin(mac, ip);
  //GESTIONE TIMER LOG
  Udp.begin(localPort);
  setSyncProvider(getNtpTime);
  while(timeStatus()== timeNotSet)
  //GESTIONE SD
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    return;
    Serial.println("card initialized.");
    pinMode(PinMov,INPUT);
 // api_status = Agentuino.begin();
 // Agentuino.onPduReceive(pduReceived);
  return;
  int Presenza;
  char data_presenza;
  String h,m,s;
  double Limite = 27;
  // listen/handle for incoming SNMP requests
  //  Agentuino.listen();
  // sysUpTime - The time (in hundredths of a second) since
  // the network management portion of the system was last
  // re-initialized.
  if ( millis() - prevMillis > 1000 )
    // increment previous milliseconds
    prevMillis += 1000;
    // increment up-time counter
    locUpTime += 100;
   Temperatura = int(Thermister(analogRead(Pinmode)));
   File dataFile = SD.open("Temp.log", FILE_WRITE);
       // if the file is available, write to it:
       if (dataFile) {
       dataFile.print("Temperatura: ");
       dataFile.println(Temperatura);
       Serial.println(Temperatura);
       dataFile.close();
      // if the file isn't open, pop up an error:
      else {
          Serial.println("Errore apertura file!!");
   if (digitalRead(8)== 1)
       Presenza=1;
       Time = now();
       // digitalClockDisplay();
        File data = SD.open("Presenze.log", FILE_WRITE);
       if (data)
         h=String (hour());
         m=String (minute());
         s=String(second());
         String date = h+":"+m+":"+s;
         Serial.println(date);
         data.println("C'è stata una presenza!");
         data.close();
          Serial.println("No presenza");
       Presenza=0;
//PAGINA WEB HTTP
Client client = server.available();
if (client) {
boolean currentLineIsBlank = true;
while (client.connected()) {
  if (client.available())
      char c = client.read();
      readString.concat(c); //store characters to string
         // COSTRUZIONE PAGINA HTML
         client.println("Content-Type: text/html");
         client.println();
         // inizializzo pagina (da togliere se uso ajax)
         client.print("<html><head><title>ARDUINO Controllo Ambientale Meucci2</title><meta http-equiv='Content-Type' content='text/html; charset=iso-8859-1' ></head><body>");
         //inizai il body
         client.println("<div style='width:360px; height:520px;'>"); //risoluzione per nokia 5800 640x360
         client.println("<H3>STATUS SENSORI DC MEUCCI-2</H3><hr />");         //Scrive sul browser il valore del termistore
         client.println("<p>TEMPERATURA = ");
         client.print(Temperatura);
         client.println(" C <br /></p>");
         client.print("ALLARME PRESENZA: ");
         if (Presenza== 1){
             client.print("<font style='color:red'>HIGH</font>");
             client.print("LOW");
          client.println("<br>");
         //Scrive sul browser il valore della fotoresistenza
         // firma
         client.println("<hr />");
         client.print("<h4>Visita <a href='http://www.infracom.it.it' target='_blank' />www.infracom.it</a></h4>");
         // chiudo il div
         client.println("</div>");
         // chiudo pagina da togliere se uso ajax
         client.println("</body></html>");
         // pulisco la stringa per la successiva lettura
         readString="";
         //fermo il client
         client.stop();
         //if c == /n
       // if client available
   // while client connesso
   // listen for incoming Ethernet connections:
Logged
New River, Arizona
Offline Offline
God Member
Arduino rocks
View Profile
WWW
To check and see if you are running out of memory distribute some "Serial.println(freeMemory());" in the code.  I've found I need a couple of hundred bytes free or the device dies erratically.  If you are running out of memory, use PSTR to handle strings and get some back.  I noticed you already include MemoryFree.h.
strcpy_P(buffer,PSTR("string text goes in here"));
Serial.println(buffer);
Hope this helps
Logged
Trying to keep my house under control http://www.desert-home.com/
Verona (VR)
Offline Offline
Newbie
View Profile
Thanks!
I need some libraries in order to use strcpy_P and PSTR?
Daniele
Logged
New River, Arizona
Offline Offline
God Member
Arduino rocks
View Profile
WWW
Yes, there is a MemoryFree library, google for the latest location.  I honestly can't remember where I got it a few months ago.  It's simple and works well.
Logged
Pages: [1]   Go Up
Print
Jump to:
