Topic: Arduino temperature&presence sensor with web page and SNMP (Read 5873 times) previous topic - next topic
moscaciccia
Hi, we are develop a project with arduino for monitor temperature and presence. We have to reach the state by web and with SNMP polling, also save some data in a SD card.
We use Arduino Uno + Eth Shield (SD), an analog thermistor and one PIR.
The task are:
  • client webpage build on arduino showing the temperature and if there's a precence
  • write on SD card when is disclose a presence
  • response to SNMP request with the temperature state and other some parameter
The sketch seem to work fine, but it crash a lot of time, and we doesn't know if is a memory problem, or other software issue.
Have someone find other similar problem and could help us?
moscaciccia
This is part of our code:
#include <Streaming.h>         // Include the Streaming library
#include <Ethernet.h>          // Include the Ethernet library
#include <Flash.h>
#include <SPI.h>
#include <MemoryFree.h>
#include <Agentuino.h>
#include <SD.h>
#include <Time.h>
#include <Udp.h>
 Ethernet.begin(mac, ip);
 //GESTIONE TIMER LOG
 Udp.begin(localPort);
 setSyncProvider(getNtpTime);
 while(timeStatus()== timeNotSet)
 //GESTIONE SD
 Serial.print("Initializing SD card...");
 pinMode(10, OUTPUT);
 if (!SD.begin(chipSelect)) {
   Serial.println("Card failed, or not present");
   return;
   Serial.println("card initialized.");
   pinMode(PinMov,INPUT);
// api_status = Agentuino.begin();
// Agentuino.onPduReceive(pduReceived);
 return;
 int Presenza;
 char data_presenza;
 String h,m,s;
 double Limite = 27;
 // listen/handle for incoming SNMP requests
 //  Agentuino.listen();
 // sysUpTime - The time (in hundredths of a second) since
 // the network management portion of the system was last
 // re-initialized.
 if ( millis() - prevMillis > 1000 )
   // increment previous milliseconds
   prevMillis += 1000;
   // increment up-time counter
   locUpTime += 100;
  Temperatura = int(Thermister(analogRead(Pinmode)));
  File dataFile = SD.open("Temp.log", FILE_WRITE);
      // if the file is available, write to it:
      if (dataFile) {
      dataFile.print("Temperatura: ");
      dataFile.println(Temperatura);
      Serial.println(Temperatura);
      dataFile.close();
     // if the file isn't open, pop up an error:
     else {
         Serial.println("Errore apertura file!!");
  if (digitalRead(8)== 1)
      Presenza=1;
      Time = now();
      // digitalClockDisplay();
       File data = SD.open("Presenze.log", FILE_WRITE);
      if (data)
        h=String (hour());
        m=String (minute());
        s=String(second());
        String date = h+":"+m+":"+s;
        Serial.println(date);
        data.println("C'รจ stata una presenza!");
        data.close();
         Serial.println("No presenza");
      Presenza=0;
//PAGINA WEB HTTP
Client client = server.available();
if (client) {
boolean currentLineIsBlank = true;
while (client.connected()) {
 if (client.available())
     char c = client.read();
     readString.concat(c); //store characters to string
        // COSTRUZIONE PAGINA HTML
        client.println();
        // inizializzo pagina (da togliere se uso ajax)
        client.print("<html><head><title>ARDUINO Controllo Ambientale Meucci2</title><meta http-equiv='Content-Type' content='text/html; charset=iso-8859-1' ></head><body>");
        //inizai il body
        client.println("<div style='width:360px; height:520px;'>"); //risoluzione per nokia 5800 640x360
        client.println("<H3>STATUS SENSORI DC MEUCCI-2</H3><hr />");         //Scrive sul browser il valore del termistore
        client.println("<p>TEMPERATURA = ");
        client.print(Temperatura);
        client.println(" C <br /></p>");
        client.print("ALLARME PRESENZA: ");
        if (Presenza== 1){
            client.print("<font style='color:red'>HIGH</font>");
            client.print("LOW");
         client.println("<br>");
        //Scrive sul browser il valore della fotoresistenza
        // firma
        client.println("<hr />");
        client.print("<h4>Visita <a href='http://www.infracom.it.it' target='_blank' />www.infracom.it</a></h4>");
        // chiudo il div
        client.println("</div>");
        // chiudo pagina da togliere se uso ajax
        client.println("</body></html>");
        // pulisco la stringa per la successiva lettura
        readString="";
        //fermo il client
        client.stop();
        //if c == /n
      // if client available
  // while client connesso
  // listen for incoming Ethernet connections:
draythomp
To check and see if you are running out of memory distribute some "Serial.println(freeMemory());" in the code.  I've found I need a couple of hundred bytes free or the device dies erratically.  If you are running out of memory, use PSTR to handle strings and get some back.  I noticed you already include MemoryFree.h.
strcpy_P(buffer,PSTR("string text goes in here"));
Serial.println(buffer);
Hope this helps
moscaciccia
Thanks!
I need some libraries in order to use strcpy_P and PSTR?
Daniele
draythomp
Yes, there is a MemoryFree library, google for the latest location.  I honestly can't remember where I got it a few months ago.  It's simple and works well.
