Topic: problem about serial (Read 701 times) previous topic - next topic
jimidini
HI, I'm trying to send data between two arduino but I've a little problem.
The TX/RX modules are rf 443MHz. the TX print via serial two message "X1234" and "X4321"
The rx module read the buffer but when I try to put an IF there's a problem:
#include <SoftwareSerial.h>
int  car[3] ;
int carattere;
void setup(){
Serial.begin(2400);
void loop(){
 riprova:
 for (int i = 0; i < 4; i++) {
     car[i] = 0;
 if (Serial.available()){
   if (char(Serial.read()) != 'X'){
       goto riprova;
if (char(Serial.read()) != '1'){
       goto riprova;
   car[0] = Serial.read(); // Then: Get them.
   car[1] = Serial.read(); // Then: Get them.
   car[2] = Serial.read(); // Then: Get them.
   Serial.print(char(car[0]));
   Serial.print(char(car[1]));
   Serial.println(char(car[2]));
If I delete the second IF it's ok but with do nothing....
Any suggestion??.
Many thanks
AWOL
#1
Apr 06, 2011, 11:41 am Last Edit: Apr 06, 2011, 11:45 am by AWOL Reason: 1
goto's are rarely needed in C.
Try using "while" or "do..while" constructs.
You have three consecutive "Serial.read"s, but no guarantee that there is data for them to read.
"car" is only declared with three elements.
jimidini
I understand this, but Isn't the problem... the goto it's ok...
ok, but if I delete the second IF it's ok... I've tryed also this
if (char(var) == 'X' && char(var) =='1')
but same result... nothing..
thank you
AWOL
 for (int i = 0; i < 3; i++) {
     car[i] = 0;
 do {
  while (Serial.available() == 0);
 } while (Serial.read()) != 'X');
 for (int i = 0; i < 3; ++i) {
   car[i] = Serial.read();
