Topic: noobs guide on setting up code::blocks for arduino uno on linux (kubuntu) (Read 299 times) previous topic - next topic
hewi
I assume linux OS, arduino uno atmega 328P, and quite some mileage in code::blocks
1 - create project folder:  /home/me/AvrProject_2018
2 - install code::blocks
3 - install arduino IDE
4 - install avr-gcc and avrdude toolchain: ~$apt-get install avrdude binutils-avr gcc-avr avr-libc gdb-avr
5 - open arduino IDE, compile a basic blink sketch selecting the correct arduino avr chip, find the temp .o file (called core.o), rename this file to lib_atmega328P-core.o, copy this file to /home/me/AvrProject_2018/arduino
6 - find the arduino header files, usually situated in arduino-installation-directory/hardware/arduino/avr/cores/arduino/ and copy all .h files into /home/me/AvrProject_2018/arduino, don't foget the pins_arduino.h in arduino-installation-directory/hardware/arduino/avr/variants/standard/
7 - Run Codeblocks
8 - top menu -> settings -> global compiler settings -> set to "GNU AVR GCC compiler", DON"T FORGET to also, in the "search directories" subtab of this menu ->
  • Compiler: add "/usr/lib/avr/include"
  • linker: add "usr/lib/avr/lib"
9 - codeblocks -> new project -> AVR -> select folder /home/me/AvrProject_2018 and create project ArduinoUnoProject -> Debug and Release is OK -> atmega 328p and only select F_CPU define and create hex files -> done
10 - right click ArduinoUnoProject and go to build options
  • in master tab (on left) -> linker settings -> link library -> add -> find -> /home/me/AvrProject_2018/arduinolib_atmega328P-core.o -> OK
  • in debug tab -> pre/post build steps- > post build steps- > add
    avr-objcopy -R .eeprom -R .fuse -R .lock -R .signature -O ihex $(TARGET_OUTPUT_FILE) $(TARGET_OUTPUT_DIR)$(TARGET_OUTPUT_BASENAME).hex
    avr-objcopy --no-change-warnings -j .eeprom --change-section-lma .eeprom=0 -O ihex $(TARGET_OUTPUT_FILE) $(TARGET_OUTPUT_DIR)$(TARGET_OUTPUT_BASENAME).eep
  • release  tab -> pre/post build steps- > post build steps- > add
    avrdude -v -patmega328p -carduino -P/dev/ttyACM0 -b115200 -D -Uflash:w:$(TARGET_OUTPUT_FILE) $(TARGET_OUTPUT_DIR)$(TARGET_OUTPUT_BASENAME).hex
11 - right click ArduinoUnoProject and add files recursively form folder /home/me/AvrProject_2018/arduino
12 - open main.c file in your project and C-V below code
Code: [Select]
#include "arduino/Arduino.h"
int main(){
    init(); //Don't forget this!
    pinMode(13,OUTPUT);
    while(1){
    digitalWrite(13,HIGH);
    delay(50);
    digitalWrite(13,LOW);
    delay(1700);
13 - save -> debug build -> sort out errors and warnings and typo's and c-v errors and stuff -> repeat 13 till 'process terminated with status 0'
14 - save -> plug arduino uno into USB and check if correct port is used in your avrdudu release post build steps! -> relase build -> sort out errors and warnings and typo's and c-v errors and stuff -> repeat 13 till 'process terminated with status 0'
15 - your uno should blink fraction of a second, like it is in standby :)
interesting info here:
arduino avr Eclipse setup
arduino avr codeblocks programmer
avrfreaks codeblocks setup avrdude
