Hello I followed the instructions mentioned here :
http://itp.nyu.edu/physcomp/Labs/MIDIOutput and then I did this :
The video explains the problems I am encountering.
the code that I used is :
const int switchPin = 10; // The switch is on Arduino pin 10
const int middleC = 60; // Middle C (MIDI note value 60) is the lowest note we'll play
const int LEDpin = 13; // Indicator LED
// Variables:
byte note = 60; // The MIDI note value to be played
//int AnalogValue = 0; // value from the analog input
int lastNotePlayed = 0; // note turned on when you press the switch
int lastSwitchState = 0; // state of the switch during previous time through the main loop
int currentSwitchState = 0;
// set the states of the I/O pins:
pinMode(switchPin, INPUT);
pinMode(LEDpin, OUTPUT);
// Set MIDI baud rate:
Serial.begin(31250);
blink(3);
// My potentiometer gave a range from 0 to 1023:
//AnalogValue = analogRead(0);
// convert to a range from 0 to 127:
//note = AnalogValue/8;
currentSwitchState = digitalRead(switchPin);
// Check to see that the switch is pressed:
if (currentSwitchState == 1) {
// check to see that the switch wasn't pressed last time
// through the main loop:
if (lastSwitchState == 0) {
// set the note value based on the analog value, plus a couple octaves:
// note = note + 60;
// start a note playing:
noteOn(0x90, note, 0x40);
// save the note we played, so we can turn it off:
lastNotePlayed = note;
digitalWrite(LEDpin, HIGH);
note ++;
if (note == 72)
note = 60;
else { // if the switch is not pressed:
// but the switch was pressed last time through the main loop:
if (lastSwitchState == 1) {
// stop the last note played:
noteOn(0x90, lastNotePlayed, 0x00);
digitalWrite(LEDpin, LOW);
// save the state of the switch for next time
lastSwitchState = currentSwitchState;
// plays a MIDI note. Doesn't check to see that
// cmd is greater than 127, or that data values are less than 127:
void noteOn(byte cmd, byte data1, byte data2) {
Serial.print(cmd, BYTE);
Serial.print(data1, BYTE);
Serial.print(data2, BYTE);
// Blinks an LED 3 times
void blink(int howManyTimes) {
int i;
for (i=0; i< howManyTimes; i++) {
