Topic: LM335A and arduino (Read 1 time) previous topic - next topic
finarfin
Hi all,
i've tried to use a lm335a themperature sensor with my arduino uno board. But i'm not sure if i'm doing everything correctly. (I'm very new to arduino and electronics).
I connected the sensor to arduino as shown in figure:
And the code that i used is that:
int pin = 0; // analog pin
 Serial.begin(9600); // start serial communication
   pinMode(12, OUTPUT);
digitalWrite(12,HIGH);
float valRead = analogRead(pin) * 0.004882814;
float  k = ((100*valRead)-273.15);
Serial.println(k);
Now i'm not sure about the results (i did not checked the temperature in my room) are here: http://pastebin.com/uMCEFvGQ
As you can see the temperature seems to be abbout 16-17 degrees.
The fact that i don't understand are why the values change so many times (and sometimes it have very strange values, like 5.66 degrees) Notice that in after the 50th value i put my fingers on the sensors.
My questions are:
1. The sensor is wired correctly?
2. These values can be ok?
3. THere are some errors in my code?
Thanks a Lot!
Ivan
I believe in Fairies :)
MarkT
It seems you are sometimes seeing a few bad values but most are OK - perhaps there is some electrical noise causing the rogue readings?
You can take several readings in succession and average them to help reduce the noise.  Perhaps a small capacitor from the analog pin to ground (say 1nF) could help.
If you have long wires then you might be picking up RFI or switching transients from household appliances - use screened cable for low level signal wires of any length.
[ I won't respond to messages, use the forum please ]
