Topic: makefile:631: *** multiple target patterns. Stop. (SOLVED) (Read 447 times) previous topic - next topic
2n3904
I'm trying to compile the Caterina bootloader on Windows 7 but keeps getting:
Code: [Select]
I suspect it has something to with this line in the makefile?
Code: [Select]
OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
2n3904
I'm using the Makefile at https://github.com/arduino-org/Arduino/blob/master/hardware/arduino/avr/bootloaders/caterina/Makefile
DrAzzy
Are there spaces in any of the paths? It looks to me like they may not be handling that case correctly. Try compiling from a location where there aren't any spaces in the path and see if that works.
Alternately, can you see what the command line being generated there is?
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
2n3904
No spaces in the paths.
Here's a screenshot of Windows command line. https://pasteboard.co/HMaNM2i.png
Budvar10
There is in makefile:
Code: [Select]
# make all = Make software.
and
Code: [Select]
# To rebuild project do "make clean" then "make all".
 Try it.
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
2n3904
make clean or make all results in the same error message.
Budvar10
#6
Nov 08, 2018, 12:10 pm Last Edit: Nov 08, 2018, 12:27 pm by Budvar10
As I see, you are trying it from Windows CMD. Probably you need something like MinGW installed to do it or to use Linux.
Budvar10
#7
Nov 08, 2018, 12:39 pm Last Edit: Nov 09, 2018, 06:27 am by Budvar10
Just out of curiosity I tried on Linux. Firstly, it cannot find LUFA. Secondly, I used LUFA from Caterina-ORG but it ends with error:
Code: [Select]
-------- begin --------
avr-gcc (AVR_8_bit_GNU_Toolchain_3.5.3_1700) 4.9.2
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C: Descriptors.c
avr-gcc -c -mmcu=atmega32u4 -I. -gdwarf-2 -DF_CPU=16000000UL -DF_USB=16000000UL -DBOARD=BOARD_USER -DARCH=ARCH_AVR8 -DBOOT_START_ADDR=0x7000UL -DDEVICE_VID=UL -DDEVICE_PID=UL -D USB_DEVICE_ONLY -D DEVICE_STATE_AS_GPIOR=0 -D ORDERED_EP_CONFIG -D FIXED_CONTROL_ENDPOINT_SIZE=8 -D FIXED_NUM_CONFIGURATIONS=1 -D USE_RAM_DESCRIPTORS -D USE_STATIC_OPTIONS="(USB_DEVICE_OPT_FULLSPEED | USB_OPT_REG_ENABLED | USB_OPT_AUTO_PLL)" -D NO_INTERNAL_SERIAL -D NO_DEVICE_SELF_POWER -D NO_DEVICE_REMOTE_WAKEUP -D NO_SOF_EVENTS -D NO_LOCK_BYTE_WRITE_SUPPORT -Os -funsigned-char -funsigned-bitfields -ffunction-sections -fno-inline-small-functions -fpack-struct -fshort-enums -fno-strict-aliasing -Wall -Wstrict-prototypes -Wa,-adhlns=./Descriptors.lst -ILUFA-111009/ -std=c99 -MMD -MP -MF .dep/Descriptors.o.d Descriptors.c -o Descriptors.o
<command-line>:0:12: error: 'UL' undeclared here (not in a function)
Descriptors.c:56:28: note: in expansion of macro 'DEVICE_VID'
  .VendorID               = DEVICE_VID,
make: *** [Descriptors.o] Error 1
Then, I tried Caterina-ORG and it worked.
My OS is customized Linux Mint Mate 16.
2n3904
#8
Nov 08, 2018, 03:07 pm Last Edit: Nov 08, 2018, 03:15 pm by 2n3904
Thanks for suggesting Linux. I just tried it on my Game Boy Zero with Raspberry Pi Zero in it and RetroPie installed (Raspbian linux) and it works great. I compiled it successfully. :)
Installed these packages on RetroPie:
Code: [Select]
sudo apt-get install gcc-avr binutils-avr avr-libc
Thanks again!
Just out of curiosity I tried on Linux. Firstly, it cannot find LUFA. Secondly, I used LUFA fro Caterina-ORG but it ends wit error:
Code: [Select]
Budvar10
