Topic: triggering sound and led in response to LDR (Read 327 times) previous topic - next topic
bidouilleelec
Why bother scaling the output of the analogRead() into a range of float values just to test if it's within some limits? Instead, just scale the limits of your comparison to work with the (0-1023) range produced by analogRead(). That's a static operation that can be done once at compile-time, much better than a run-time operation that's computed for EVERY comparison.
+1
PaulS
Quote
Still, it's bad code unless that is its purpose.
That IS its purpose, but it would be far better to include a comment in the code that says that.
Code: [Select]
if(!myDFPlayer.begin(mySyupidNameForASoftwareSerialInstance))
    // Useless comments on the ends of these line removed. Some people...
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    // Do nothing until the wiring problem is fixed or an SD card is inserted
    while(true);
pranghead
so... Im still struggling with this. really struggling to understand how to use millis to get an mp3 file to play once and then wait for further input, such as the LDR picking up a change in light, to carry on and carry out another procedure. How do you get something to rely on one thing finishing to start another???
Code: [Select]
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
float b;
const int ledPin = 3;
const int ledpingreen = 5;
const int switchpin = 6;
const int LDR = A5;
int LDRValue = 0; // variable to store the value coming from the sensor
int prev_LDRValue = 0; // variable to store the previous state of the sensor
long startOnLDR = 0; // The Last time that input was recieved
unsigned long currentMillis = 0;    // stores the value of millis() in each iteration of loop()
const long interval = 1000;
//mp3 stuff
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX               //
DFRobotDFPlayerMini myDFPlayer;                                  //
void printDetail(uint8_t type, int value);                       //
  mySoftwareSerial.begin(9600);                                  //
  Serial.begin(115200);                                          //
  Serial.println();                                              //
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)")); //
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.  //
    Serial.println(F("Unable to begin:"));                                                   //
    Serial.println(F("1.Please recheck the connection!"));                                   //
    Serial.println(F("2.Please insert the SD card!"));                                       //
    while(true);        //
pinMode (ledPin, OUTPUT); //red LED
pinMode (ledpingreen, OUTPUT); //green LED
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.setTimeOut(8000); //Set serial communictaion time out 500ms
  //----Set volume----
  myDFPlayer.volume(20);  //Set volume value (0~30).
  //----Set different EQ----
  myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
  //----Read imformation----
  Serial.println(myDFPlayer.readState()); //read mp3 state
  Serial.println(myDFPlayer.readVolume()); //read current volume
  Serial.println(myDFPlayer.readEQ()); //read EQ setting
  Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
  Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
  Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read file counts in folder SD:/03
void loop(){
currentMillis = millis();
b=analogRead(A5);
b=b*5/1023;
Serial.println(b); //prints the values coming from the sensor on the screen
if(b>=4.0&&b<=5.00)
{digitalWrite(5,HIGH);
myDFPlayer.play (1);
delay (500);
else{
 digitalWrite (5 , LOW);
 digitalWrite (3, HIGH);
while(digitalRead(3) == HIGH)
{ myDFPlayer.play (3);
delay (100); }
currently the mp3's just play in a loop. I want to trigger a second mp3 to play once when the LDR is uncovered and then when then wait for the LDR to be covered again to reset. Any help would be greatly appreciated
PaulS
Quote
You need to look at the state change detection example. While that specifically refers to digital state changes associated with switches (from pressed to released or from released to pressed), it doesn't take much imagination to extend it to analog values - the value is above the threshold this time but was not last time or the value is below the threshold this time but was not the last time or the value.
You want to trigger the player ONLY when the state changes. As it is now, you are trigger the player when the value IS above the threshold or IS below the threshold, rather than when the values GOES ABOVE or GOES BELOW the threshold.
pranghead
thanks paul thats a really good insight, ill have a look at that now and try and wrap my skull around it
pranghead
Ive tried looking at states and state detection and I get how they work, Im just still struggling to apply it to using an analogue read. Not sure how to make the mp3 sound for 1 second only when the analogue read first gets a reading of over 4.0 and then not play anything else until the analogue read drops bellow a certain reading. Ive tried using millis and states, im just confused on the appropriate way of using them in this context.
Code: [Select]
void loop(){
b=analogRead(A5);
b=b*5/1023;
if(b>=4.0&&b<=5.00)
delay (300);
still having to use a delay at the moment, and this obviously just loops round and round while its receiving this analogue read
PaulS
Quote
Unless you save the current reading as the previous reading (or the current state as the previous state), you will never be able to do that.
If you HAD looked at the state change detection example, the fact that the example has variables for the current and previous readings should have been obvious.
Your code does not.
