Topic: Printing in landscape through ethernet shield on port 9100 (Read 992 times) previous topic - next topic
Apr 07, 2011, 10:06 am Last Edit: Apr 07, 2011, 10:08 am by MHDfo Reason: 1
Hi everyone,
I'm using a Arduino mega with a modified ethernet shield to send data to a printer (actually through a Jetdirect module)...
It's working quite fine except i didn't find the way to setup the printer an print in landscape instead of portrait.
Is anyone had an idea about it ?
Interesting, can you post your code?
HP printers have escape codes to set attributes:  Landscape = 27 38 108 49 79 (decimal values
A complete (printer dependant) list can be found on: - http://www.dragon-it.co.uk/links/hp_pcl_codes.htm
Rob Tillaart
Apr 07, 2011, 12:06 pm Last Edit: Apr 07, 2011, 12:10 pm by MHDfo Reason: 1
All the code is based the pachatube tutorial and on someone's else work found on the net  but i didn't note whom and where... sorry for that
I just post here the code for printing something over 9100 port. My full  program is useless for people I think.
/!\ you need  PCL 5E compatible printer or something like that ( Meaning printer which use proprietary protocol should not work)
/*              test        */
/*      mac de la carte    byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xXX, 0xXX };          */
#include <SPI.h>
#include <Ethernet.h>
byte ip[] = { 192, 168, 1, XXX }; // IP of our arduino
byte server[] = { 192, 168, 1, YYY}; // IP of our printer
Client client(server, 9100);
long lastConnectionTime = 0;
boolean lastConnected = false;
const int postingInterval = 30000;
  Ethernet.begin(mac, ip);
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  if (client.available()) {
    char c = client.read();
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
   // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
  // store the state of the connection for next time through
  // the loop:
  lastConnected = client.connected();
void sendData() {
    // if there's a successful connection:
    if (client.connect()) {
    client.println("Hello Word");
    // note the time that the connection was made:
    lastConnectionTime = millis();
  else {
    // if you couldn't make a connection:
    Serial.println("connection failed");
I have try different way with differents representation but my main problem is how to give parameters to printer.
The xxx.print() , xxx.println() and xxx.write() are just print like other text.
The printer didn't interpret the code, it just print it out.
Any clue for me ?
Maybe try this way....
    client.print("\033&l10");    // [ESC] & l 1O to go to Landscape
I am actually used to controlling landscape/portrait via a job ticket that comes before the main print job.  This escape sequence is pretty old-school, but likely works.
Thanks for answering but unfortunately it doesn' t work. Anyway that the first time the printer don't print the code.
It prints : "ello Word"
with the write() or print()
println() just print "Hello Word" but still in portrait mode at least the printer seem to read something
I will try some other combinaison but other ideas are welcome
You might test printing the escape sequences byte per byte: 27 38 108 49 79 (decimal values
followed by print("hello");
get the idea?
What exact printertype is it?
Its interpreter might slightly differ.. or just not support landscape;    URL manual?
Rob Tillaart
