Topic: Upload error on Arduino Nano, ATmega328P (Read 109 times) previous topic - next topic
DannyPhunk
He guys, first time trying to upload anything to this board i got as part of a synth build, but it won't upload :c I have checked through the troubleshooting guide to no avail, heres the error code!
Code: [Select]
Arduino: 1.8.7 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 3288 bytes (10%) of program storage space. Maximum is 30720 bytes.
Global variables use 27 bytes (1%) of dynamic memory, leaving 2021 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\DANIEL~1\AppData\Local\Temp\arduino_build_747677/grainsV21.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Any help would be much appreciated
sterretje
Try 'old bootloader' from tools->processor.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
DannyPhunk
You absolute genius, I can't believe I didn't even think of checking for this, thank you so so much!!
sterretje
Current state of affairs:
'old boot loader' is for clones and the pre 2018 originals. 328P is for the originals manufactured in 2018.
