Topic: ESP32 HardwareSerial (Read 528 times) previous topic - next topic
Pacpat
Hello,
i have some trouble with esp32 an HardwareSerial!
here my script for testing the Serial....
#include <HardwareSerial.h>
HardwareSerial Myserial(1);
void setup(){
   Myserial.begin(9600);
    Myserial.println("Hello World");
    Serial.println("Hello World");
Serialprint run fine It Shoows me pic1
But MyserialPrint shows me some characters.... pic2
I would be glad if someone could help me with this....
Thank
Patrik
GypsumFantastic
What's the baud rate setting in serial monitor?
Pacpat
The Serial Monitor has 9600 baut on both (Serial and MySerial)...
darrob
Try changing
Code: [Select]
to
Code: [Select]
Myserial.begin(9600, SERIAL_8N1, RXD, TXD);[code]
where RXD and TXD are the pins you're using
Pacpat
same resualt... pic :smiley-confuse:
darrob
How do you have it wired up?
Are you using a usb to ttl device?
Provide a schematic/wiring diagram
Pacpat
#6
Nov 09, 2018, 04:03 pm Last Edit: Nov 09, 2018, 04:05 pm by Pacpat
here some pics.....
darrob
#7
Nov 09, 2018, 04:13 pm Last Edit: Nov 09, 2018, 04:15 pm by darrob
That looks like a USB to RS-232 device. I don't think it works in the way you're using it.
You need a USB to TTL device, similar to this. or this.
You can find cheaper ones on ebay I'm sure.
Idahowalker
Also, for the DUE and the ESP32, I found that a Serial.flush() after the end of a serial print sequence helps rid those funky printer characters.
