Topic: Getting incorrect MIDI signals (Read 1 time) previous topic - next topic
tinkerabout
I've created a pedal board using this schematic (apart from the analog inputs):
The code for the project is below. The switching part works fine, midi is send when a switch is clicked. The problem is when I monitor the results using Midi Monitor instead of getting different notes on the same channel I get the same note on different channels instead. Also about half of the time I get 2-3 messages from a single switch.
This is me cycling through each of the eight switches, note the duplicates:
15:09:51.543 From MIDI Port Note On 8 G8 1
15:09:53.496 From MIDI Port Note On 9 G8 1
15:09:53.497 From MIDI Port Note On 9 G8 1
15:09:54.238 From MIDI Port Note On 10 G8 1
15:09:54.239 From MIDI Port Note On 10 G8 1
15:09:54.997 From MIDI Port Note On 11 G8 1
15:09:54.998 From MIDI Port Note On 11 G8 1
15:09:55.785 From MIDI Port Note On 12 G8 1
15:09:57.628 From MIDI Port Note On 13 G8 1
15:09:58.412 From MIDI Port Note On 14 G8 1
15:09:59.177 From MIDI Port Note On 15 G8 1
#include "Midi.h"
// MIDI Class
Midi midi(Serial);
int lastRead[8];
  // Configure digital pins for input.
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, INPUT);
  pinMode(7, INPUT);
  pinMode(8, INPUT);
  pinMode(9, INPUT);
  midi.begin(0);
  // Grap the current on / off switch state
  for (int i=0; i <= 7; i++){
    lastRead[i] = digitalRead(2+i);
// MIDI channel to send messages to
int channelOut = 1;
int baseNote = 40;
int velocity = 127;
void doKeys()
  for (int i = 0; i<= 7; i++) {
   // check to see if a switch state as changed, if so output a note and set the current state
   if (lastRead[i] != digitalRead(2+i)) {
     midi.sendNoteOn(baseNote+i,velocity,channelOut);
  doKeys();
Any Ideas?
tinkerabout
Updated the Midi library and Arduino, threw in some delays and now it is working like a champ.
#include <MIDI.h>
int lastRead[8];
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, INPUT);
  pinMode(7, INPUT);
  pinMode(8, INPUT);
  pinMode(9, INPUT);
  MIDI.begin(0);
int channelOut = 1;
int baseNote = 40;
int velocity = 127;
void doKeys()
     MIDI.sendNoteOn(baseNote+i,velocity,channelOut);
   delay(1);
  doKeys();
  delay(10);
