Topic: vusb and linked assembly problem (Read 1 time) previous topic - next topic
sbanzaert
I'm trying to get the vusb (http://code.google.com/p/vusb-for-arduino/) code (the UsbKeyboard branch) installed and working on Arduino-22 and I need some help understanding how Arduino handles linked .S (assembly) files.
What is the correct way to link a .S file to a project?  I have gone through the Sketch > Add file... dialog which appears to work -- the selected file (usbdrvasm.S) is now in the data/ subdirectory of my sketch.  But when I try to compile I get the error
Code: [Select]
undefined reference to `usbCrc16Append'
This function is defined in usbdrvasm.S and (I believe properly) prototyped in another header file:
Code: [Select]
#ifdef __cplusplus
extern "C"{
#endif
extern unsigned usbCrc16Append(unsigned data, uchar len);
#ifdef __cplusplus
} // extern "C"
#endif
Is this error a sign of the assembly not being properly linked?  Of the prototype in the header not working properly?  Some other toolchain error?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
