Topic: Avrdude not able to upload to leonardo with ubuntu 18.10 (Read 489 times) previous topic - next topic
manufwi
Hi all,
odd issue and I would like to know if I am the only one with this. I have been uploading sketches with arduino 1.8.6 on my linux box (ubuntu 16.xx,17.xx and 18.04) with no problem (uno, mega and leonardo).
Now since I upgraded to ubuntu 18.10 no joy for leonardo anymore! I am still able to upload to Uno and Mega though.
I did not change the arduino toolchain at all, only the rest ;-) was upgraded. I suspect a problem with the new CDC driver.
In any case this is the log:
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/emmanuel/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
         User configuration file is "/home/emmanuel/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM1
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "/tmp/arduino_build_164818/RR-duino.ino.hex"
avrdude: writing flash (18572 bytes):
Writing | avrdude: butterfly_recv(): programmer is not responding
avrdude: error: programmer did not respond to command: write block
 ***failed;
 ***failed;
repeated a lot and then several:
avrdude: Error: butterfly programmer uses avr_write_page() but does not
provide a cmd() method.
 *** page 127 (addresses 0x0000 - 0x007f) failed to write
with different page numbers
BTW I can still upload sketches to my leonardo on another linux box, but first I have to reflash the bootloader (that I can do on the problematic linux box via a tinyUSB !!)
Anyone could help pls?
TIA
Manu
sakdask
No you are not the only one. I've had this problem since upgrading as well. I've had to rely on Windows for the uploads.
I hope this get's fixed soon.
manufwi
OK I will try to see on Ubuntu forum if something comes up.
sakdask
manufwi
Nope, nothing from the UBUNTU forum, will try the avrfreaks one maybe...
manufwi
Sorry guys I got no answer from Ubuntu forums, the bug I opened on Launchpad did not get any attention either. Can we raise this issue to someone with longer arms ;-)?
Bye
Manu
