Topic: Debugger on the mkrzero (Read 672 times) previous topic - next topic
Rohling_Wuchter
can someone post a link to a documentation on how to connect the j-link OB ARM emulator debugger via SWD with the mkrzero? Do I need additional hardware? Thanks in advance.
Best regards
ballscrewbob
It depends on what additional hardware you already have to hand ?
This topic covers a small amount of the information you need.
A better topic HERE
Awaiting an atmel ICE myself as not had much luck with some other debuggers but that is probably just me.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Rohling_Wuchter
thanks for the links. I have no additional hardware. I've seem, that on the MKR GSM1400 one has the SWDIO/SWDCLK pins readily available, whereas on the MKRZERO one has to soldier the inputs manually.
To be clear, I only have the j-link Segger Edu Mini for ~15 bucks. I will Post, whether it worked with the MKRGSM1400 and MKRzero.
