Loading...
Pages: [1] 2 3 4   Go Down
Author Topic: LED clock with different time speed  (Read 1295 times)
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
I am new to this and need some guidance where to start.
I am doing a project for an exhbition where I want to use 4 digit 7 segments LED displays to display time. The time is supposed to be running too fast (double or triple normal time or so) until someone interacts and normal time (and speed) is shown.
I have found some resources how to display time but how do I plan the project so that I get the normal time displayed with the input?
I have an Arduino Duemilanove..
Thankful for any advice.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Reading an input and changing the speed which the time is displayed/counted is easy.
Most of the effort here will be interfacing with the LEDs and counting time properly.  Figure this much out and the rest will be obvious.
Logged
www.cmiyc.com - A guide to being an Enginerd
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
We need to know a bit more...
Do you need to show the correct time?
What will the speeded up time show, and will the time go back to "correct" when someone interacts?
Do you need the time to be accurate?
Does the Arduino need to automatically know the time at power up, or are you happy to set it every time you turn it on?
What speed are you showing?
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
Correct time needs to be shown (when in normal speed).
When the time is speeded up you need to notice that it is going too fast so I guess maybe 120 times quicker than normal is okay.
On a second thought, maybe I need 6 digits to include seconds. That way it is easier to see that the clock is going too fast.
Yes, the time needs to go back to correct time when someone interacts.
The time can be reset once a day if needed at startup.
Thanks.
Logged
Offline Offline
Tesla Member
View Profile
WWW
So pretty simple then, you don't need an RTC, just roll your own,
I would organize a 1/nth-second timer and two counters that count modulo 60/60/24. Then every 1/nth of a second update one counter (this is you fast counter) and every n interrupts update the other one (the real time counter).
So now we have two counters running counting H:M:S but one is n times faster than the other.
When someone interacts with the device set a flag (and possibly reset the fast counter with the value from the real time counter, depends on what you want to show)
Write a routine to display a "time", it gets called every nth of a second, it tests the flag and either displays the fast or slow counter.
That's pretty much it I think, plus of course you have to be able to set the time so that will need a few buttons, dip switches or something.
Logged
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
Feels great that you are saying its pretty simple smiley
I'll give it a try and see how far I manage...
Thanks
Logged
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
This is what I have now. Probably not the best way of making it but it works with the counting...
I tried to follow graynomad's advice but now this is what I have.
I want it to count slower (speed = 1000) when a button is pressed. I have tried to change the code so it would just change the delay to 1000 and also just made a copy of the whole loop more or less with a longer delay but nothing works.
Can somebody help how I can make it work?
Code:
int latchpin3 = 8; // connect to pin 12 on the second'595
int clockpin3 = 12; // connect to pin 11 on the second'595
int datapin3 = 11; // connect to pin 14 on the second'595
int latchpin2 = 5; // connect to pin 12 on the minute'595
int clockpin2 = 7; // connect to pin 11 on the minute'595
int datapin2 = 6; // connect to pin 14 on the minute'595
int latchpin1 = 3; // connect to pin 12 on the hour'595
int clockpin1 = 9; // connect to pin 11 on the hour'595
int datapin1 = 4; // connect to pin 14 on the hour'595
float b = 0;
int c = 0;
float d = 0;
int e = 0;
int speed = 10; // used to control speed of counting
int segdisp[10] = {
63,6,91,79,102,109,125,7,127,111 };
pinMode(latchpin1, OUTPUT);
pinMode(clockpin1, OUTPUT);
pinMode(datapin1, OUTPUT);
pinMode(latchpin2, OUTPUT);
pinMode(clockpin2, OUTPUT);
pinMode(datapin2, OUTPUT);
pinMode(latchpin3, OUTPUT);
pinMode(clockpin3, OUTPUT);
pinMode(datapin3, OUTPUT);
  for (int z=0; z<24; z++)  // count to 24 hours
  for (int x=0; x<60; x++)  // count to 60 minutes
  for (int y=0; y<60; y++)  // count to 60 seconds
// Count
    digitalWrite(latchpin1, LOW);
    shiftOut(datapin1, clockpin1, MSBFIRST, 0); // clears the right display
    shiftOut(datapin1, clockpin1, MSBFIRST, 0); // clears the left display
    digitalWrite(latchpin2, LOW);
    shiftOut(datapin2, clockpin2, MSBFIRST, 0); // clears the right display
    shiftOut(datapin2, clockpin2, MSBFIRST, 0); // clears the left display
    digitalWrite(latchpin3, LOW);
    shiftOut(datapin3, clockpin3, MSBFIRST, 0); // clears the right display
    shiftOut(datapin3, clockpin3, MSBFIRST, 0); // clears the left display
      digitalWrite(latchpin1, HIGH);
      if (z<10)
        shiftOut(datapin1, clockpin1, MSBFIRST, segdisp[z]); // sends the digit down the serial path of hours
        shiftOut(datapin1, clockpin1, MSBFIRST, 63); // sends the digit down the serial path of hours
    else if (z>=10)
      d=z%10; // find the remainder of dividing z by 10, this will be the right-hand digit
      c=int(d); // make it an integer, c is the right hand digit
      b=z/10; // divide z by 10 - the whole number value will be the left-hand digit
      e = int(b); // e is the left hand digit
      digitalWrite(latchpin1, LOW); // send the digits down to the shift registers!
      shiftOut(datapin1, clockpin1, MSBFIRST, segdisp[c]);
      shiftOut(datapin1, clockpin1, MSBFIRST, segdisp[e]);
  if (x<10)
    shiftOut(datapin2, clockpin2, MSBFIRST, segdisp[x]); // sends the digit down the serial path of minutes
    shiftOut(datapin2, clockpin2, MSBFIRST, 63); // sends the digit down the serial path of minutes
    digitalWrite(latchpin2, HIGH);
  else if (x>=10)
    d=x%10; // find the remainder of dividing x by 10, this will be the right-hand digit, minutes
    b=x/10; // divide x by 10 - the whole number value will be the left-hand digit, minutes
    digitalWrite(latchpin2, LOW); // send the digits down to the shift registers!
    shiftOut(datapin2, clockpin2, MSBFIRST, segdisp[c]);
    shiftOut(datapin2, clockpin2, MSBFIRST, segdisp[e]);
  digitalWrite(latchpin3, HIGH);
    if (y<10)
       shiftOut(datapin3, clockpin3, MSBFIRST, segdisp[y]); // sends the digit down the serial path
       shiftOut(datapin3, clockpin3, MSBFIRST, 63); // sends the digit down the serial path
    else if (y>=10)
     d=y%10; // find the remainder of dividing y by 10, this will be the right-hand digit
     b=y/10; // divide y by 10 - the whole number value will be the left-hand digit
     digitalWrite(latchpin3, LOW); // send the digits down to the shift registers!
     shiftOut(datapin3, clockpin3, MSBFIRST, segdisp[c]);
     shiftOut(datapin3, clockpin3, MSBFIRST, segdisp[e]);
  delay (speed);
Logged
Offline Offline
Tesla Member
View Profile
WWW
Hi sinuslinus,
I'm having trouble following the masses of code but some things to do first I think,
You don't need all those latch/clock/data pins, you can connect all 3 shift registers in series and only have a single latch, clock and data pin. Then for example your clearing code would be something as simple as this.
Code:
   digitalWrite(latchpin, LOW);
    // clear all displays
    for (int x=0, x < 3; x++)
        shiftOut(datapin, clockpin, MSBFIRST, 0);
     digitalWrite(latchpin, HIGH);
Which will write 3 null bytes into the 3 SRs thus clearing them. Not that you need to clear them every loop, the new values will be written over the old values, clearing as you have will only cause flicker.
Next thing,
Code:
Firstly, what does this do? From what I can see
Code:
z = 23;
x = 59;
y = 59;
Would do the same thing, so you don't actually have any counters. Also use meaningful variable names (yes I know I didn't above but that was a tight loop that could viewed all at once, your x,y,z get used elsewhere, for example what does "if (z<10)" do, rather "if (hours<10)".
Next thing, you are mixing up the calculations with the IO, do one then the other.
Code:
loop() {
   int digits[3];
   // calc_all_digits_and_put_in_digits_array
        shiftOut(datapin, clockpin, MSBFIRST, digits[x]);
Code:
float b = 0;
int c = 0;
float d = 0;
Why do you need floats to calc the time? Then you have to change them back to ints anyway.
It's late here, but if you can clean up some of that we can have another look at it.
Rob
« Last Edit: September 18, 2010, 10:37:29 am by graynomad » Logged
Offline Offline
Tesla Member
View Profile
WWW
It's way after my bed time but I thought I'd give you a start. I think something like this will have a chance of working.
Code:
#define SECONDS 0;
#define MINUTES 2;
#define HOURS   4;
uint_8 latchpin = 8;  // connect to pin 12 on the '595
uint_8 clockpin = 12; // connect to pin 11 on the '595
uint_8 datapin  = 11; // connect to pin 14 on the '595
uint_8 speed = 10;    // used to control speed of counting
uint_8 seconds = 0;
uint_8 minutes = 0;
uint_8 hours = 0;
uint_8 digits[6];
uint_8 segdisp[10] = {63,6,91,79,102,109,125,7,127,111};
   pinMode(latchpin, OUTPUT);
   pinMode(clockpin, OUTPUT);
   pinMode(datapin, OUTPUT);
   if (++seconds > 59) {
      seconds = 0;
      minutes++;
   if (minutes > 59) {
      minutes = 0;
      hours++;
   if (hours > 23) {
     hours = 0;
   digits[SECONDS]   = seconds / 10;
   digits[SECONDS+1] = seconds % 10;
   digits[MINUTES]   = minutes / 10;
   digits[MINUTES+1] = minutes % 10;
   digits[HOURS]     = hours   / 10;
   digits[HOURS+1]   = hours   % 10;
   for (int x=0, x < 6; x++)
        shiftOut(datapin, clockpin, MSBFIRST, segdisp(digits[x]));
   delay (speed);
It's still doesn't handle your original problem of a fast and slow clock, and I think the digits will be reversed, but it's a start.
Rob
« Last Edit: September 18, 2010, 10:43:14 am by graynomad » Logged
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
I based it on this:
http://tronixstuff.wordpress.com/2010/05/06/getting-started-with-arduino-chapter-five/
and to be honest I don't really now how this works, it just works :-). First I just used 3 pins and all shift registers in series but I didn't manage to get all the displays working properly and just seconds counting.
And I have no answer why I am using floats.
I have 6 SRs in pairs, thats the way I got all displays working.
I have a look at this and see what happens. Thanks a lot.
/ Linus
Logged
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
I understand the idea of simplifying the code but I don't get everything.
Is uint_8 unsigned int ? Arduino doesn't compile uint_8
It didn't want to compile several other things but this works:
Code:
#define SECONDS 0
#define MINUTES 2
#define HOURS   4
unsigned int latchpin = 8;  // connect to pin 12 on the '595
unsigned int clockpin = 12; // connect to pin 11 on the '595
unsigned int datapin  = 11; // connect to pin 14 on the '595
unsigned int speed = 10;    // used to control speed of counting
unsigned int seconds = 0;
unsigned int minutes = 0;
unsigned int hours = 0;
unsigned int digits[6];
unsigned int segdisp[10] = {63,6,91,79,102,109,125,7,127,111};
   if (++seconds > 59)
      seconds = 0;
      minutes++;
   if (minutes > 59) {
      minutes = 0;
      hours++;
   if (hours > 23) {
     hours = 0;
   digits[SECONDS] = seconds / 1  ;
   for (int x = 0; x < 6; x++)
   delay (speed);
I'll wire it up and see what happens..
But how can I get the change of speed and preferably a way to set the start "time"? O yes, when you press the button it should go back to the fast speed again after 10 seconds.
Okay really, I realized today that want all six displays to just flicker in the fast mode. Hmm that is, like the are all just rolling numbers quickly.
And at best show normal time for 10 seconds when the button is pressed.
Otherwise it looks like a bomb and not a spinning clock...
Logged
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
I did a quick wiring but the segments are all wrong.
Number 1 is shown as the top horizontal segment for instance.
And it doesn't shift down to the next display either. smiley-sad
It starts counting on two displays (if I set speed to 1000 it shows seconds on two displays) but when reaches 10 they show differently.
Logged
Offline Offline
Tesla Member
View Profile
WWW
Quote
That implies that either your wiring is wrong OR the values in segdisp are wrong, like this
FWIW I find with these type of bit pattern lookup tables it's better to use hex or binary and lay it out to be easy to read.
Code:
short LED_data [] = {                 // abcdefg.
            0xfc,      //       0       %11111100
            0x60,      //       1      %01100000
            0xda,      //       2      %11011010
            0xf2,      //      3      %11110010
            0x66,      //      4      %01100110
            0xb6,      //      5      %10110110
            0xbe,      //      6      %10111110
            0xe0,      //      7      %11100000
            0xfe,      //      8      %11111110
            0xf6,      //      9      %11110110
            0xee,      //      A      %11101110
            0x3e,      //      b      %00111110
            0x9c,      //      C      %10011100
            0x7a,      //      d      %01111010
            0x9e,      //      E      %10011110
            0x8e      //      F      %10001110
Quote
That all points to wiring, can you post the exact circuit you have?
Quote
Do you have all 6 SRs wired in series?
Quote
uint_8
Sorry about that, it was late after all, firstly it should have been uint8_t, and secondly your unsigned int is the same.
« Last Edit: September 19, 2010, 04:43:03 am by graynomad » Logged
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
The values are correct. It has been working with the old code.
I went back a step and
this is what you wrote:
Code:
shiftOut(datapin, clockpin, MSBFIRST, segdisplay(digits[x]));
Arduino wont accept this:
 "In function 'void loop()':
error: 'segdisplay' cannot be used as a function"
I changed that part to be able to compile it last night as posted but I think this is where the problem is, since your original code didn't. Can you have a look at this?
All 6 SRs are daisychained.
« Last Edit: September 19, 2010, 06:13:20 am by sinuslinus » Logged
London, UK
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
Sorry, a picture or the specs?
Its pretty much the same as Excerise 5.1 here:
His displays have the same pins as mine but on the SRs his pins are different.
I use these:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=483-6645
Logged
Pages: [1] 2 3 4   Go Up
Print
Jump to:
