Topic: LED clock with different time speed (Read 8692 times) previous topic - next topic
Graynomad
#30
Sep 21, 2010, 06:24 am Last Edit: Sep 21, 2010, 06:27 am by graynomad Reason: 1
Code: [Select]
     slow_display = TRUE;
This shouldn't have been there, I was playing with another option and forgot to take it out.
That's your compiler error but not the logic problem.
One way or another there should ba some kind of display even 000000, is that the case?
Rob Gray aka the GRAYnomad www.robgray.com
sinuslinus
Graynomad
Comment out this
Code: [Select]
// detect falling edge of button
  // record the time and set flag to indicate we are timing for 10 secs
  if (digitalRead (BUTTON) == LOW && button_state == HIGH) {
        time_but_pressed = millis();
        button_state == LOW;
       timing = TRUE;
  // if it's been 10secs since we started timing reset the flag
  if (millis () > time_but_pressed + 10 * 1000) {
     timing = FALSE;
So now we're almost back to the working code. What happens?
sinuslinus
If comment out means take away, then we are counting seconds again.
Graynomad
Quote
Pretty much, you can just cut the text or wrap it in /* */ comment codes.
So there's a problem in that piece of code, put it back and remove one of the "if" blocks, see what happens, then put that back and remove the other and see what happens. Try to determine exactly which line of code causes the problem.
Meanwhile I'll have a think.
sinuslinus
I took away the second if and then it counts but nothing happens when I press the button. Haven't doublechecked the button though but its time for the bed.
Graynomad
Two problems, one small one big.
Initialise the timing variable
Code: [Select]
unsigned int timing = FALSE;
And the classic C gotcha
Code: [Select]
if (ticks = 0) {
should be
Code: [Select]
if (ticks == 0) {
Still may not be right but no chance with that.
sinuslinus
Quote
Nope, but it counts with both "if" in the code now but no action when button is pressed.
I made a testsketch for the button setup and the button is wired correctly.
sinuslinus
I am trying to understand and as far as I can see there is nothing saying that all displays should be counting the "ticks".
Now it acts as the previous counter ss:mm:hh
I put an extra pair of brackets after tick and now it counts 1/10th seconds but still just the first digit and then when hitting the highs pushes over to the next one.
Code: [Select]
[glow]{[/glow]if (seconds > 59) {
     seconds = 0;
     minutes++;
  if (minutes > 59) {
     minutes = 0;
     hours++;
  if (hours > 23) {
     hours = 0;
  }[glow]}[/glow]
Graynomad
#39
Sep 21, 2010, 04:08 pm Last Edit: Sep 21, 2010, 04:12 pm by graynomad Reason: 1
Back up a bit.
Quote
Is this still the case (without the new braces) and how fast does it count?
Quote
All it should do at present is count the same either way, just slower when the button is pressed.
sinuslinus
#40
Sep 21, 2010, 04:15 pm Last Edit: Sep 21, 2010, 04:19 pm by sinuslinus Reason: 1
Weird, it counts the same without the brackets. Wonder what I was looking at... So the brackets do nothing.
Code: [Select]
No action when pressing button.
Graynomad
Code: [Select]
  if (timing == FALSE) {
[glow]     digitalWrite(latchpin, LOW);
     for (int x = 0; x < 6; x++)
        shiftOut(datapin, clockpin, MSBFIRST, segdisp[digits[x]]);
     digitalWrite(latchpin, HIGH);  [/glow]
     if (ticks == 0) {
If we are not timing the 10 seconds the yellow bit gets executed 10 times a sec.
If we are timing the other half runs and this tests for tick == 0, therefore it only runs every 10 times, ie every second.
Graynomad
#42
Sep 21, 2010, 04:22 pm Last Edit: Sep 21, 2010, 04:23 pm by graynomad Reason: 1
What speed is it counting at?
Quote
Do you mean it stops or that nothing changes?
sinuslinus
Okay,
it counts 10th of seconds.
When I press the button nothing changes.
Graynomad
Change
Code: [Select]
to
Code: [Select]
timing = TRUE;
Does it now count at 1Hz?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
