Topic: where do i find forum guidelines on cross-posting. (Read 388 times) previous topic - next topic
Mully911
please help I do not want to get another timeout...
Juraj
http://forum.arduino.cc/index.php/topic,148850.msg1118325.html#post_etiquette
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
AWOL
Employ some common sense.
Edit: I notice you even managed to duplicate this topic.
In the same forum section, FFS.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Robin2
The simple answer to the question in the title is "don't cross-post"
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
ballscrewbob
Also mentioned in many of the STICKY threads at the top of most sections too.
Of course that requires the ability to read those posts and understand them.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
MAS3
As mentioned: don't cross post.
But if you find yourself in a situation where you end up posting in some incorrect forum, report your post to a moderator.
You can do so by clicking the link below your post, but above your signature (if you'd have one).
Ask the moderator to either remove the post, or to move it to the right place (telling the moderator where, in your opinion, it should go).
But don't make a habit of doing this, moderators are quite busy over here and really don't need the extra work.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
westfw
"Cross Posting" - posting the same question in multiple places.
If you have a question, it may seem like it's a good idea to post it in all the categories where it might apply.
Say, if you're having trouble with your Internet-of-Things thermostat, you could ask in the "Project Guidance" section, and in the "Networking, Protocols, and Devices" section, and perhaps the "Home Automation and Networked Objects" section.  That way, appropriate parties will see your question even if they don't read all of the forum sections, and you're more likely to get an answer, right?
Don't Do That!!
it's particularly annoying to the people who read the question more than once.  Worse, an answer you get will probably show up in only one place, making things difficult for anyone searching for a similar topic, and answers that could have built on one another to make a good discussion might instead be isolated, and less generally useful.
The object of forums like the Arduino Forum is not just to answer your question, but to serve as an archive of knowledge.  Having the same question in multiple places, with perhaps disparate answers, make it less useful in that respect.  It's considered pushy and impolite, and will get you put in time-out...
Cross posting to other, further-away forums (like avrfreaks.net, or stack exchange) is a bit more ambiguous.  I know it still annoys some of our most prolific posters, but the "communities" and even "personality" of other forums can be quite different, so it's not as "bad."
There is general agreement that if you DO cross-post further away, that you also:
  • tell us that you've done so.
  • if you get an answer somewhere else, tell us, and let use know as well (and/or post links.)
