Topic: 4 wire pc fan question (Read 837 times) previous topic - next topic
kurama
Hello guys,
   Does anybody know what the facnspecs :
http://www.formfactors.org/developer/specs/4_Wire_PWM_Spec.pdf
mean by 2 pulses per revolution, tach output. Is there one Hall or 2?
johnwasser
Could be one Hall and two magnets or one magnet and two Halls.  Does it matter?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
kurama
Hey John, nice to hear from you.
    The problem is that i want to know exactly how many times per revolution an output signal is send from the tach. I think that there is one hall and one magnet, and the first pulse is the start and the second the end, so 2 pulses/rev. Using this info i can get a math model of the fan, which in turn i will use to make a pid controller.
    If you have any ideas on my Hall problem, please let me know :)
    Mircea.
PS: sorry for my English, not my first language
johnwasser
The spec doesn't say how long each pulse is but I believe they mean two full pulses per revolution LOW HIGH LOW HIGH.  Make sure you use a pull-up resistor because it's an open-collector output (only drags the line down to 0v, won't supply +v).
