Loading...
Pages: [1]   Go Down
Author Topic: 7segment displays with max7219 chip counting  (Read 540 times)
Offline Offline
Newbie
View Profile
hello all,
i have just started using arduino from various other C based controllers and have a uni project that im trying to sort out asap.  i have 2 7segment displays mutiplexed up and working fine, but im trying to work out how i can have a potentiometer connected to control the digits that have been displayed.  The hardwear works fine its just my coding abilities that i am having trouble with. In fact i have no idea how to start.
any help would be gratefully appreciated
cheers
adknott
Logged
USA
Offline Offline
Jr. Member
ClockTHREE Rocks!
View Profile
WWW
I'd start by writing a function
// set/unset segments of display identified by display_id
void seven_seg_contol(int display_id, uint8_t bits){
    for(uint8_t i = 0; i < 8; i++){
    if(1 && bits >> i){
        // light up the ith segment of display_id
    else{
        // unlight the ith segment of display_id
Then define constants for each digit.
const uint8_t ONE = 0b00010001;  // just for instance I don't really know which bits to be on or off
const uint8_t TWO = 0b01111001;  // just for instance I don't really know which bits to be on or off
Then write a higher level function display
void seven_seg_display(uint8_t two_digit_num){
   // ones digit
    switch(two_digit_num % 10){
    case 1:
        seven_set_control(ONES_DIGIT, ONE);
   // tens digit
    switch(two_digit_num / 10){
    case 1:
        seven_set_control(TENS_DIGIT, ONE);
Logged
Pages: [1]   Go Up
Print
Jump to:
