Topic: Error digitalRead from char (Read 319 times) previous topic - next topic
REM14
I want to read the digital pins from a given number of connections. Since the name of those numbers does not follow a consecutive order, I had to define an array. Those names start with PR and a the number. I've achieved to print on the screen the names correctly like PR5, PR6, PR7.... using the sprintof command. However, I cannot use the char buffer (where the names are located) to read the digital pin value. I got the following error:
Code: [Select]
C:\Users\ In function 'void loop()':
C:\Users\:100:36: warning: invalid conversion from 'char*' to 'uint8_t {aka unsigned char}' [-fpermissive]
           read = digitalRead(buffer);
In file included from sketch\Master_Tester_TX.ino.cpp:1:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:135:5: note:   initializing argument 1 of 'int digitalRead(uint8_t)'
 int digitalRead(uint8_t);
Find the code below. Note that those digitalRead functions inside a For loop are placed inside a Switch case.
Code: [Select]
int read;
x_arr = new int[15] {5, 6, 7, 9, 10, 11, 15, 16, 17, 21, 22, 23, 25, 26, 27};
      x = 15;
      if (digitalRead(buttonStart) == HIGH)
        char buffer[32];
        for (int i = 0; i < 15; i++) {
          int s = x_arr[i];
          sprintf(buffer, "PR%d", s);
          delay(delay_);
I've also tried to convert the buffer (char) into uint8, but it does not work.
How can I solve this?
Thanks
PaulRB
#1
Nov 15, 2018, 08:24 pm Last Edit: Nov 15, 2018, 08:32 pm by PaulRB
Thank you for using code tags. But please read the forum guide in the sticky post in full and then modify your post above and fix it.
Using a string as the parameter to digitalRead() is nonsense. Please describe what you are trying to do in more detail. Please do not try to use technical words that you may not understand. Just use pain English.
I can't be sure, but perhaps you meant
Code: [Select]
          read = digitalRead(s);
maxim2511
Why Your buffer is empty? And why You use char for that?
Did You use arduino? Or another platform?
Normally on arduino
"  arraypin[] = {A0, A1, A2,A3};  " is working properly, and using
"  int mew = analogRead(arraypin[2]);  " should not have any problems.
In Your code, U=You try read from array what dont have any value in side. Is empty.
Ps, if You want convert string from keyboard, Use function " String(data) "
like:
"  string words;
int value;
words = String(value);  "
converts value to the character alfabet.
" int x;
char w;
w = char(x) "
converts character to integer.
" char w;
int x:
x = int(w); "
This way
sterretje
buffer is a character array; why do you use it in the digitalRead that takes an int as a parameter? x_arr is the array with the pins (and is of type int); you can use it directly.
Without seeing the full code, be aware that when using the new keyword, you also have to delete the array; else you have a recipe for exhausting your memory.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
REM14
Maxim2511, how should I define the array? int or char? I got an error about it.
Paul__B
Hmmm, what are you actually putting into this array?
Oh yes, characters, from a serial input.
Well, that just happens to be what "char" means!
Also same as 8-bit bytes.
REM14
I know it is char. Using this line
Code: [Select]
char *arraypin [] = {"PR5", "PR6", "PR7", "PR9", "PR10", "PR11", "PR15", "PR16", "PR17", "PR21", "PR22", "PR23", "PR25", "PR26", "PR27"};
But it does not work.
Note that I'm defining the char array inside a switch case statement inside the void loop.
Paul__B
Then something else is wrong.  Simple as that.
sterretje
Code: [Select]
Maybe time to post your complete code. And tell us which board you're using.
