Topic: PIR connection (Read 997 times) previous topic - next topic
amjlopez
Hello:
I have bought a PIR BENTEL VISUS99 (model a)
http://www.secpoint.it/listing/Manuali/Antintrusione/Bentel/VISUS99.pdf,
and I donĀ“t know how to connect to arduino. I was looking for tutorial PIR and only have three cables:
GND, +5V and OUTPUT, but this VISUS99  PIR have two for 12V that I use a power supply but have two more cables to connect (N/C), Do you know how to do it?. Do I have to put any resistor to get pir input?
thank you very much.
Simpson_Jr
Unfortunately the manual doesn't tell much.
The sensor apparently needs 12 volt to run,
the output seems a relay.
If it is, you could read it as a switch, but I'd use a multimeter first to be sure.
AWOL
Most cheap PIRs will have a simple relay output for compatibility with legacy alarm systems; some will have both NO and NC connections.
I'm afraid I don't read Spanish.
