Loading...
Pages: [1] 2   Go Down
Author Topic: bug in Ethernet lib ? (Arduino mega, w5100)  (Read 3661 times)
Munich, Germany
Offline Offline
Jr. Member
View Profile
Hello to all,
this is my first post (as I have the arduino only since one week now).
I have a Arduino Mega with ethernet shield and  arduino-0022 SW, but the Webserver-Example does not work.
The web browser keeps waiting for an answer, that does not come.
I changed the example to echo whatever comes in at the arduino:
Code:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,0, 111 };
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
Server server(80);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  blink();
  // listen for incoming clients
  Client client = server.available();
  if (client) {
    blink();
          client.println("HTTP/1.0 200 OK");
          client.println("Content-Type: text/plain");
          client.println();
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    int i = 0;
    while (client.connected()) {
      if (client.available()) {
        blink2();
        char c = client.read();
        client.print(c);
        i++;
        if (i > 2000) {
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          //client.println("HTTP/1.0 200 OK");
          //client.println("Content-Type: text/html");
          client.println();
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(analogRead(analogChannel));
            client.println("<br />");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
void blink() {
      digitalWrite(13, HIGH);   // set the LED on
      delay(200);              // wait for a second
      digitalWrite(13, LOW);    // set the LED off
      delay(500);              // wait for a second
void blink2() {
      delay(60);              // wait for a second
And this is, what comes in in the browser window now:
Code:
GET /index.html HTTP/1.1
Host: 192.168.0.111
User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.1.16) Gecko/20110107 Iceweasel/3.5.16 (like Firefox/3.5.16)
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language:GET /index.html HTTP/1.1
Host: 192.168.0.111
Host: 192.168.0.111
[...and.so.on.and.so.on...]
Conclusion 1: The example software never "sees" an empty line, and so never starts to send the HTTP response.
Conclusion 2: My first thought was, that the web browser is re-sending its request over and over due some socket state problem or so, but then I realized, that the reading from internal read buffer in the w5100 chip is always starting to read from the beginning.
(I noticed in W5100Class::recv_data_processing
the lines
    ptr += len;
    writeSnRX_RD(s, ptr);
which should actually do it.)
My main questions for now are:
1) Why is nobody else reporting problems with the Ethernet library or Server example?
2) Can anybody confirm this problem?
(Who knows, maybe it turns out to be a somehow broken ethernet shield after all.)
Thanks in advance for any suggestions.
« Last Edit: April 11, 2011, 09:24:06 am by Thomas33 » Logged
A mouse is a device to point at the xterm you want to type in.
0
Online Online
Tesla Member
Arduino rocks
View Profile
Below is some server test code I use that might help you do some trouble shooting.
Code:
//zoomkat 12-18-10
//routerbot code
//for use with IDE 0021
//open serial monitor to see what the arduino receives
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
Server server(84); //server port
String readString;
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("servertest1"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString);
  //now output HTML data header
  client.println("HTTP/1.1 204 Zoomkat");
  client.println();
  client.println();
  delay(1);
  //stopping client
client.stop();
//clearing string for next read
readString="";
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Munich, Germany
Offline Offline
Jr. Member
View Profile
Hi Edison,
echoing to the serial could be another idea.
However, your code would not exploit the problem, as it appears only after reading in more that 253 (+/- ?) byte from the socket. (I just counted the bytes from one "GET ..." to the next repetition.)
Can you please check the Webserver example with either your code changed to echo more (I guess it needs more than replacing " < 100" with "< 300", due to string length restrictions), or just test the example I posted?
I dare to get a confirmation on this errorenous behaviour, to know where to continue searching (sw or hw).
Thank you,
Thomas
Logged
Munich, Germany
Offline Offline
Jr. Member
View Profile
Hello,
I think I found the error(s) now by myself:
1.
In w5100.cpp we have the method W5100Class::getRXReceivedSize. This method can tell, if and how much data is available. However, this method is only used in client (and udp), but in the client it only checks, if data is available, not using the actul byte count. This is probably where the whole problem starts.
2.
W5100Class::recv_data_processing just reads the wanted number of bytes (len) from the chip, not asking, if they are valid (came in).
3.
In socket.cpp the comment for recv states:
Quote
"It continues to wait for data as much as the application wants to receive."
Actually it does not wait. It just returns this number of bytes, getting them from the chip receive buffer, not asking if they were received or not.
Additionally, the commented behaviour by itself is not what you might expect from a recv call to a socket. The linux manpage states:
Quote
... return  the length of the message on successful completion."
In other words: At least when you want to use a keep-alive connection, you do not know, how much will come in next time. So you don't want to tell it, how long (for how many bytes) it shall wait. Instead, you want it to get the info, how much it got.
After so much bug complaining, I fell the need to point out,
that THE WHOLE CODE IS REALLY GOOD STYLE PROGRAMMING, FUN TO READ AND EASY TO UNDERSTAND, and it's a pleasure to fix it. Thanks to the author(s).
One last word: I need the buggy behaviour being confirmed, otherwise I won't send a fix ;-)
« Last Edit: April 12, 2011, 02:36:55 am by Thomas33 » Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
The below site has code that seems similar to what you want to do. I think you can pot your own code in brackets by opening the post to modify, high light the code and then click the # on the tool bar, then save.
http://www.scienceprog.com/getting-hands-on-arduino-ethernet-shield/
« Last Edit: April 09, 2011, 09:35:01 am by zoomkat » Logged
Munich, Germany
Offline Offline
Jr. Member
View Profile
Thanks zoomcat, I will have a close look at this link.
Logged
Munich, Germany
Offline Offline
Jr. Member
View Profile
Hello,
I still need a confirmation, that the webserver example
   Examples > Ethernet > WebServer     from arduino SW version 22
is not working, if you request with a "standard browser" like IE, firefox or so. The behaviour is, that the web browser waits "forever".
Please, can anybody confirm this, or tell me, that it is working for him!
Thanks for cooperation
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Modifying the code for my lan, your code produces this after a really long wait.
Quote
GET /hgfds HTTP/1.1
Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, application/x-ms-application, application/x-ms-xbap, application/vnd.ms-xpsdocument, application/xaml+xml, */*
Accept-Language: en-us
UA-CPU: x86
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; (R1 1.5); .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Host: 192.168.1.102:84
Connection: Keep-Alive
analog input 0 is 318<br />
analog input 1 is 246<br />
analog input 2 is 222<br />
analog input 3 is 198<br />
analog input 4 is 164<br />
analog input 5 is 184<br />
Logged
Munich, Germany
Offline Offline
Jr. Member
View Profile
Thanks again zoomcat for your investigation.
Looks like the behaviour is different at your place. Please let me ask further questions:
1) The "very long delay" may be caused by the blink2() calls in my program, in combination
  with a different behaviour of your browser (not echoing each char immediately, as it does for me).
  => Please test again without the blink/blink2-calls.
2) What happens at your place, when you run the original WebServer example?
3) Maybe I should come back to suspecting the HW. When I am back home, I will see, if I
   can find any revision number or so off my Ethernet Shield, and compare it
   with anything from yours.
Thanks for sticking to this issue.
Logged
Offline Offline
Newbie
View Profile
hi. i couldn't help to notice that we are having kind of similar problems....I think.
I've installed and run the program on this site
and it works fine when not connected to anything.
But when I connect an LED or whatever the page hangs infinitely.....
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
@Thomas33: I have a problem just like that. What did you do to correct it?
I get hung in the "while(client.available())" loop forever. The bytes available returned never gets smaller than 1024.
Dude! If you can come up with the solution, I will nominate you for "Arduino Linux King", and I don't think anyone here would challenge it.
EDIT: If you want to see what I have found so far:
http://arduino.cc/forum/index.php/topic,68624.0.html
Please excuse the references to "B.S." My bad.
That was prior to understanding the situation here.
« Last Edit: August 14, 2011, 09:18:56 am by SurferTim » Logged
Offline Offline
Faraday Member
View Profile
@Thomas33: I'm sorry. You did not make it to "Arduino Linux King". Found it on my own. See the link above.
Logged
Italy
Offline Offline
Newbie
View Profile
WWW
For what is worth, I can confirm this bug when using an Arduino Uno.
If I use Firefox or Konqueror, I get no answer. If I telnet port 80 or use wget, I get the correct answer.
Logged
Italy
Offline Offline
Newbie
View Profile
WWW
Just tested compiling sketch from a windoze VM, and it works.
So it seems it's a compiler bug.
I reread instructions/prerequisites and in fact in Mandriva 2010.2 there are:
cross-avr-gcc-c++-4.4.3-7mnb2
cross-avr-binutils-2.20.51.0.4-1mnb2
avr-libc-1.6.8-1mdv2010.1
cross-avr-gcc-cpp-4.4.3-7mnb2
avrdude-5.10-1mdv2010.1
cross-avr-gcc-4.4.3-7mnb2
Could be a good thing to pin it down and patch but I think I'm not skilled enough for this task.
Logged
Munich, Germany
Offline Offline
Jr. Member
View Profile
Hi SurferTim,
No, not me - but you rock!!! Thanks very much for all your investigation. You really pushed the issue, until something happend. Great!
I lost any hope in April, and just came back today to check for any progress. I haven't tested your fixes by now, but it sounds good I I look forward in confidence.
Do you have any comment about the non-standard recv call, as I wrote about in
http://arduino.cc/forum/index.php/topic,57972.msg416887.html#msg416887
As long as this call works different than a standard recv, it will be impossible to use standard SW (well, due to the kind of difference it will mostly work, but sometimes fail).
Logged
Pages: [1] 2   Go Up
Print
Jump to:
