Topic: GPS /GSM Tracker (Read 5202 times) previous topic - next topic
trenator
GPS /GSM Tracker
DESC:
With this program, Arduino waits for a phone call and send a SMS with the GPS coordinates.
Disclaimer: This is my first working version, testing was ok, but i don`t make responsible of unwanted SMS sends, use for security always  a pre-paid mode sim card. Use the code under your own responsability.
PICS:
CODE:
Code: [Select]
#include <nmea.h>
#include <NewSoftSerial.h>
#include <LCD4Bit.h>
#include<stdlib.h>
NMEA gps(GPRMC);
LCD4Bit lcd = LCD4Bit(4);
int luzfondo = 13 ;
char cadena [500] ;
float valor ;
float valor2 ;
int pos ;
char buf[12];
char buf2[12];
char buf3[9];
int i ;
int notificaciones;
NewSoftSerial GPS(5,6);
NewSoftSerial modem(3,4);
int esperatono ;
void setup(){
lcd.init();
pinMode(luzfondo, OUTPUT);
modem.begin (9600);
digitalWrite(luzfondo, HIGH);
GPS.begin (4800);
delay (2000);
if (GPS.available() > 0 ) {
  char c = GPS.read();
  lcd.printIn("GPS PREPARADO");
  delay (1000);}
modem.println ("AT+CPIN=M I   P I N");
lcd.clear();
lcd.cursorTo(2, 0);
lcd.printIn("INICIALIZANDO MODEM");
delay (3000);
esperatono = 1 ;
lcd.clear();
void loop(){
if (esperatono == 1) {
modem.flush();
lcd.clear();
lcd.cursorTo(3, 0);
lcd.printIn("ESPERANDO TONO");
cadena [0] = '\0' ;
i = 0;
do {
  if (modem.available () ){
  cadena [i]  = (char (modem.read())) ;
  i++;
} while ( !strstr (cadena, "RING" ));
cadena [i] = '\0' ;
modem.flush();
lcd.cursorTo(4, 0);
lcd.printIn("TONO RECIBIDO");
delay (3000);
lcd.clear();
esperatono = 0;
pos = 0 ;
    // read incoming character from GPS
    // check if the character completes a valid GPS sentence
    if (gps.decode(c)) {
       if (gps.gprmc_status() == 'A') {
        pos = pos + 1;
        lcd.clear () ;
       //dtostrf(FLOAT,WIDTH,PRECSISION,BUFFER);
       valor = 0;
       valor2 = 0;
       valor = gps.gprmc_latitude() ;
       valor2 = gps.gprmc_longitude() ;
      lcd.cursorTo (1,0);
      lcd.printIn ("Lat: ");
      dtostrf(valor, 3, 6, buf);
      lcd.printIn(buf);
      lcd.cursorTo (2,0);
      lcd.printIn ("Lon: ");
      dtostrf(valor2, 3, 6, buf2);
      lcd.printIn(buf2);
      lcd.cursorTo (3,0);
      lcd.printIn ("Pos# ");
      itoa (pos, buf3, 10);
      lcd.printIn (buf3);
      if (pos == 20) {
      pos = 0 ;
      MandaSMS();
      notificaciones = notificaciones + 1 ;
      esperatono = 1 ;
void MandaSMS () {
      modem.println ("AT+CMGF=1");
      delay (1000);
      modem.println("AT+CMGS=+34M I   N U M E R O    D E     M O V I L");
      delay (2000);
      modem.print("longitud: ") ;
      modem.print(buf);
      modem.print("  latitud: ");
      modem.print(buf2);
      modem.println(26,BYTE);                // Escibe el Ctrl+Z
      lcd.clear();
      lcd.printIn("SMS");
      lcd.cursorTo(2, 0);
      lcd.printIn("ENVIADO");
      modem.flush();
      delay (60000);
      if (notificaciones >= 10) {
      lcd.clear();
      while(true){
      lcd.cursorTo(1, 0);
      lcd.printIn("DETENIENDO PROGRAMA");
      lcd.cursorTo(2, 0);
      lcd.printIn("DEMASIADOS SMS");
      delay(1000);}}
tytower
#1
Apr 09, 2011, 12:50 pm Last Edit: Apr 09, 2011, 12:55 pm by tytower Reason: 1
I think this is what he is saying !
With this program, Arduino waits for a phone call and then sends an SMS with the GPS coordinates.
Disclaimer: This is my first working version, testing was ok, but i don`t take responsibility for unwanted SMS sending,  for security always use  a pre-paid  sim card. Use of the code is your own responsibility.
Now Sir I like this bit of work and am wanting to build it .
What parts do I need ,where can I get them and will you please post the scematics and perhaps a construction diagram with notes .
I will not hold you responsible whatever even if it SMS's our political leaders . I would like to know where some of them are at times.
JW11
hey, i have 2 ideas
(1) checking the number before sending sms
(2) sending the data per gprs to a http-server. for example http://myserver.com/gprsinput.php?long='...'&lat='...'
msev
Trenator, could you please write the parts you used to build this project?
trenator
hi, sorry for the delay.
Parts are:
Arduino
A LM7805 attached on a board for regulate voltage to 5v. and dont overload arduino
A ttl - serial converter , because my modem speaks on rs232 and arduino in ttl levels.
Modem GSM
and GPS module
Abishai
Must read this stuff.....
http://abishaisingh.wordpress.com/2012/06/03/gsm-modem-sim-300-sending-text-sms-arduino/
it might be useful...
RudiAhlers
I'm sure this project could be "spiced up" a bit.
Does anyone know how to "read an incoming" phone number, on an Arduino? If so, please show us, cause then one one pre-program it to only send back GPS co-ordinates to a list of numbers, and not every number that phones in.
