Topic: [DS3231: CR2032 vs LIR2032] Warning! Is your module killing the battery? (Read 206 times) previous topic - next topic
rtek1000
Attention: Modules manufactured with DS3231 and an EEPROM memory may be for a different type of battery, maybe LIR2032 (rechargeable) instead of CR2032 (not rechargeable)!
If you are going to use the module with CR2032, you should remove the resistor or the diode, in the last case cut the PCB track.
If your module is still original, check the battery voltage with the module powered by 5V, if your battery has a voltage greater than 3.3V, check the module circuit. Or just check the circuit. I found a module with a 4.3V battery and expanded body.
Do not use an expanded body battery!
Please avoid private messages, your question may be someone's answer in the future!
sterretje
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
rtek1000
