Loading...
Pages: [1]   Go Down
Author Topic: How to control a 4wd robot to move by arduino?  (Read 4297 times)
Offline Offline
Newbie
View Profile
Hi everyone,
I want to control a 4wd robot to move using arduino.
http://www.dfrobot.com/index.php?route=product/product&path=35_49&product_id=97
But I am new in this region and don't know how to code.
I have assembled the robot together, also installed the arduino software. I have all the materials needed.
Can anybody tell me the process of making it move, also tell me how to code?
Thank you very much! smiley
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
Anything else while we're at it smiley
To do this we would have to analyse the Romeo controller schematic and spend a lot of time. And that's if you already now how to write code.
Surely there are examples on the dfrobot site.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
London, Ontario, Canada
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
I would like to know if you can turn without tearing the wheels off.  4WD drive usually self-destructs as wheels try to rub sideways during a turn.
Logged
Offline Offline
Tesla Member
View Profile
WWW
With no steering this would be the case with any robot wouldn't it.
And with no diff how does one handle the different travel of inside and outside wheels?
______
Rob
Logged
Boston
Offline Offline
God Member
Arduino rocks
View Profile
I built this as well as the 2 wheeled version.  Both are coded similarly.
The 4 wheel one tends to slide more than actually turn.
http://www.robotliving.com/building-robots/four-wheeled-robot/
« Last Edit: April 11, 2011, 03:14:47 pm by Pauly » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
I've seen large skid-steer consruction equipment that didn't have the wheels falling off.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Tesla Member
View Profile
WWW
Yes most Bobcats etc do this, it's hard on the gear though and needs a lot of power (depending on the surface).
Obviously tracked robots have the same issues and they seem to work.
______
Rob
Logged
Offline Offline
Full Member
View Profile
The way tanks steer is by having one tread move faster than the other. The ratio of the speeds controls the turning radius.  The bigger the turning radius the gentler the turn on the wheels.  You could do that with an Arduino.
Logged
Offline Offline
Newbie
View Profile
I'm so appreciate to see many replies, but I still feel confused. Maybe I don't ask the question clearly. Hope someone can help me with the following questions:
1.Which equipment do I need? The arduino, the assembled robot, the robot controller(board), anything else? Do I need a Ethernet shield,cable?
How to install and connect?
2.What's the theory by controlling the robot move?
3.What kind of server-side technology do you recommend? J2EE or something else?
Thank you again for your patience.
Logged
New Hampshire
Offline Offline
God Member
There are 10 kinds of people, those who know binary, and those who don't.
View Profile
WWW
You are asking for a considerable amount of information here
http://www.societyofrobots.com/step_by_step_robot.shtml
That link should give you an idea of just how much information you're asking for.  It's got nothing to do with the dfrobot 4wd platform you are looking at, but it should give you a much better idea of what's involved with building a robot piecemeal or from scratch.
Logged
Boston
Offline Offline
God Member
Arduino rocks
View Profile
To get started all you really need are four things.
1. An Arduino
2. The robot body/kit
3. Motor controller (I used one from Adafruit)
4. Batteries
Check out how I built the 2 wheeled robot.  It is almost the same for building the for wheeled robot.  http://www.robotliving.com/building-robots/two-wheeled-robot-2/
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Below is a link to a kit 4wd robot assembly instructions. You should be able to learn a lot by studying their assembly instructions.
http://www.lynxmotion.com/driver.aspx?Topic=assem05
Logged
Offline Offline
Newbie
View Profile
Hi everyone,
Thank you all for your kindly replies. Yesterday I finally get my first step, use the code involved here:http://www.dfrobot.com/wiki/index.php?title=DFRduino_RoMeo and finally the motor moves,(although only one moves, I'm still learning and fixing it).
The code involved in that link is as follows:
Code:
Sample Code:
int E1 = 5;     //M1 Speed Control
int E2 = 6;     //M2 Speed Control
int M1 = 4;    //M1 Direction Control
int M2 = 7;    //M1 Direction Control
///For previous Romeo, please use these pins.
int E1 = 6;     //M1 Speed Control
int E2 = 9;     //M2 Speed Control
int M1 = 7;    //M1 Direction Control
int M2 = 8;    //M1 Direction Control
void stop(void)                    //Stop
          digitalWrite(E1,LOW);
          digitalWrite(E2,LOW);
void advance(char a,char b)          //Move forward
          analogWrite (E1,a);      //PWM Speed Control
          digitalWrite(M1,HIGH);
          analogWrite (E2,b);
          digitalWrite(M2,HIGH);
void back_off (char a,char b)          //Move backward
          analogWrite (E1,a);
          digitalWrite(M1,LOW);
          analogWrite (E2,b);
          digitalWrite(M2,LOW);
void turn_L (char a,char b)             //Turn Left
          analogWrite (E1,a);
          analogWrite (E2,b);
void turn_R (char a,char b)             //Turn Right
          analogWrite (E1,a);
          analogWrite (E2,b);
void setup(void)
    int i;
    for(i=6;i<=9;i++)
    pinMode(i, OUTPUT);
    Serial.begin(19200);      //Set Baud Rate
void loop(void)
     char val = Serial.read();
     if(val!=-1)
          switch(val)
             case 'w'://Move Forward
                     advance (100,100);   //PWM Speed Control
             case 's'://Move Backward
                     back_off (100,100);
             case 'a'://Turn Left
                     turn_L (100,100);
             case 'd'://Turn Right
                     turn_R (100,100);
          delay(40);
      else stop();
What I used are a Duemilanove Arduino, a Romeo, a 4wd robot and of course batteries. But the problem is :
1.The code above controls only two motors, when I control four motors, where should I change?
2.As you can see, there are many switch-case in the loop method, but I never used that before,what does that mean?
For example, can I enter the word "w" to control the robot move forward? Where to enter? How can I write a java interface or web interface to control?
Thank you again for everyone's help, in this place I really learned a lot. smiley-kiss
Logged
New Hampshire
Offline Offline
God Member
View Profile
WWW
Quote
When dealing with fixed orientation motors/wheels, controlling four motors is the same as controlling two motors, because you should be controlling the motors in pairs.  There's no reason for the two motors on the left side to be driven separately (same for the right side).  Ideally, just wire the two left motors in parallel to the motor controller (making sure the motor controller can handle the current of two motors), and then wire the two right motors in parallel to the motor controller.
Logged
Boston
Offline Offline
God Member
Arduino rocks
View Profile
I would just double up your motor code.
Here are some examples from my code. I used the Adafruit motor shield.
RF = Right Front LF = Left Front, etc..
Code:
// defining motors
AF_DCMotor motorRF(1, MOTOR12_1KHZ);
AF_DCMotor motorLF(2, MOTOR12_1KHZ);
AF_DCMotor motorRR(3, MOTOR12_1KHZ);
AF_DCMotor motorLR(4, MOTOR12_1KHZ);
Code:
//Going forward
  motorRF.run(FORWARD);
  motorLF.run(FORWARD);
  motorRR.run(FORWARD);
  motorLR.run(FORWARD);
Logged
Pages: [1]   Go Up
Print
Jump to:
