Topic: question about battery (Read 783 times) previous topic - next topic
coos
is there any simple way to read a battery's voltage from arduino?
thx?
James C4S
This is a pretty common question.  Search this forum and Google for "Measure Battery."
You've given no details (why kind of battery, how often you need to measure it, what you want to do based on the reading, etc.)
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
johnwasser
For a voltage between 5V and 0V, referenced to Arduino ground:  analogRead()
For a voltage ABOVE 5V, referenced to Arduino ground:  Voltage divider (two resistors) and analogRead()
For negative voltages things get complicated.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
coos
It's 12V li-ion battery?i want to know when the battery should be replace?so i should measure it first
thx for reply
James C4S
I have found that if you want to measure the same battery the arduino is on, you need to isolate the battery from the I/O pin when un-powered.  Otherwise the atmega will get "back powered" through the I/O pin, draining your battery.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
