Loading...
Pages: 1 ... 25 26 [27] 28 29 30   Go Down
Author Topic: Guide to gyro and accelerometer with Arduino including Kalman filtering  (Read 128316 times)
0 Members and 3 Guests are viewing this topic.
Offline Offline
Newbie
View Profile
Hi Lauszus,
I've been learning a lot from your code, thanks very much for putting it on here.
I have a board with single axis gyro with 3 axis accelerometer, analogue outputs.
I'm looking to find the Roll angle, so the single gyro board will need to be orientated up on its end so that the Roll axis goes through the middle of the gyro. The accelerometers with then be: X=up/down, Y=left/right, Z=forward/backward.
In this configuration which combination of the X,Y and Z accelerometers should I be using in the code?
I am guessing that it's the X and Y as the Z axis accelerometer is not effected by roll when the board is mounted on it's end
Your code uses X and Z and Y and Z in the arctan function, so I should use X and Y, correct?
Logged
Denmark
Offline Offline
Full Member
View Profile
WWW
@richardtheboffin
It depends on your gyro - some have to be orientated up others don't.
Regarding which axis you should use on your accelerometer: I can't say for sure. It depends on how it's orientated. Either it's X and Z or Y and Z.
Try to modify this code: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/blob/master/IMU6DOF/LPR530AL_%20LY530ALH_%20ADXL335/LPR530AL_%20LY530ALH_%20ADXL335.ino, so it's uses the correct sensitivity values for your setup.
Then afterwards you can easily see which angles should be fused together.
You might also need to invert some of the readings, as I have done here: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/blob/master/IMU6DOF/LPR530AL_%20LY530ALH_%20ADXL335/LPR530AL_%20LY530ALH_%20ADXL335.ino#L51
Logged
Offline Offline
Newbie
View Profile
Hi Lauszus,
I have your code running ok with the single gyro and x,y,z accelerometers.
I'll dump the intermediate angle calculation values out and see if I can figure which pair I need to combine with the gyro.
Cheers,
Richard.
Logged
Offline Offline
Newbie
View Profile
Hi Lauszus,
All sorted out now. I had everything coded correctly but missed the initial offset from zero for the down axis accelerometer due to gravity.
It works very well and rejects linear movements really well.
Just need to feed the angle into my motor controller now.
Thanks for everything!
Logged
morocco
Offline Offline
Newbie
View Profile
please , can you share with us all the program?
Logged
Offline Offline
Newbie
View Profile
i was able to implement the filter thanks for this guide it was  really helpful...thank you very much
but i dont know how to relate these values to motor's rpm of a quadcopter so i will stabilize, can anybody post links to guides like this?
Logged
Offline Offline
Newbie
View Profile
You will need to use a PID controller to give roll,pitch,yaw outputs when the orientation deviates from 0,0,0.  However,  I have used these filters on a quadcopter and they suffer from the problem of linear acceleration affecting the pitch and roll.  The filters are fast enough, smooth and very stable (calculation time was 80micros for twin Kalmans on an Arduino Due) but you'd probably be better off using Mahonys DCM or Madgwicks filter - they're less sensitive to linear acceleration but a bit more prone to noise (vibration from the motors).
You'll find plenty of links via Google for any of this stuff.
« Last Edit: February 18, 2013, 11:46:50 am by AntR » Logged
Offline Offline
Newbie
View Profile
i want to work with MPU-6050-Triple Axis Accelerometer Gyro can it be done
Logged
Offline Offline
Newbie
View Profile
i want the same guide for MPU-6050-Triple Axis Accelerometer Gyro
Logged
morocco
Offline Offline
Newbie
View Profile
the same think , so my ,i'd like this idea and i would like  someone to share us the GUIDE of IMU 6050 and arduino
Logged
Denmark
Offline Offline
Full Member
View Profile
WWW
The setup is very similar just note that if you are using an Arduino running at 5V you might damage the IMU as it's only running at 3.3V, but some breakout boards have a logic level circuit built-in. If not use have to use a logic level converter like this one: https://www.sparkfun.com/products/8745.
To connect the Arduino with the MPU-6050, you need to connect it as it says in the following comment: https://www.sparkfun.com/products/11028#comment-50b3c165ce395f484d000000.
Hopes this helps you out for now, as I havn't got time to write a guide at the moment.
Regards
Lauszus
« Last Edit: March 28, 2013, 12:01:38 pm by Lauszus » Logged
Offline Offline
Newbie
View Profile
Hi Lauszus,
I make a little customisation of your source for digital IMUs so it can work with  Minimu-9 board , hope you don't mind.But there is something wrong here is what i get:
Code:
....(the board is on the ground and i don't touch it the whole time)
X: 180.00 Y: 180.01
X: 180.05 Y: 180.06
X: 180.22 Y: 180.14
X: 180.51 Y: 180.16
X: 180.82 Y: 180.11
X: 181.07 Y: 180.04
X: 181.42 Y: 179.92
X: 181.79 Y: 179.80
X: 182.22 Y: 179.65
X: 182.72 Y: 179.46
X: 183.23 Y: 179.28
X: 183.85 Y: 179.08
X: 184.54 Y: 178.80
X: 185.26 Y: 178.48
X: 185.99 Y: 178.02
X: 186.60 Y: 177.45
X: 187.54 Y: 176.95
X: 188.54 Y: 176.43
X: 189.64 Y: 175.72
X: 190.82 Y: 175.03
X: 192.13 Y: 174.37
X: 280.48 Y: 86.86
X: 280.43 Y: 86.66
X: 280.32 Y: 86.91
X: 280.19 Y: 87.02
X: 280.09 Y: 87.10
X: 279.97 Y: 87.32
X: 279.81 Y: 87.84
X: 279.71 Y: 87.88
X: 279.60 Y: 88.26
X: 279.51 Y: 88.09
X: 279.38 Y: 88.20
X: 279.27 Y: 88.09
X: 279.10 Y: 88.24
X: 278.96 Y: 88.26
X: 278.80 Y: 88.56
...(finally the X stopped growing and the Y stopped getting lower)
X: 278.61 Y: 89.11
X: 278.44 Y: 89.23
X: 278.29 Y: 89.41
X: 278.25 Y: 88.81
X: 278.07 Y: 89.24
X: 277.85 Y: 89.62
X: 277.68 Y: 89.88
X: 277.53 Y: 90.03
X: 277.36 Y: 90.22
X: 277.24 Y: 90.48
X: 277.12 Y: 90.17
X: 276.99 Y: 90.08
X: 276.90 Y: 89.87
X: 276.76 Y: 89.84
X: 276.61 Y: 89.97
X: 276.44 Y: 90.35
X: 276.26 Y: 90.62
X: 276.12 Y: 90.84
X: 276.02 Y: 90.76
X: 275.78 Y: 91.38
X: 275.67 Y: 91.39
X: 275.47 Y: 91.74
X: 275.32 Y: 91.92
X: 275.16 Y: 92.18
X: 275.07 Y: 92.02
X: 274.95 Y: 92.17
X: 274.83 Y: 92.30
X: 274.68 Y: 92.31
X: 274.52 Y: 92.53
X: 274.43 Y: 92.53
X: 274.27 Y: 92.90
X: 274.18 Y: 92.90
X: 274.03 Y: 92.95
..(and all over again)
and here is my source
Code:
#include <Wire.h>
#include <L3G.h>
#include <LSM303.h>
L3G gyro;
LSM303 compass;
double zeroValue[5] = {-200, 44, 660, -18.5, 52.3}; // Found by experimenting
/* All the angles start at 180 degrees */
double gyroXangle = 180;
double gyroYangle = 180;
double compAngleX = 180;
double compAngleY = 180;
unsigned long timer;
/* Kalman filter variables and constants */
const double Q_angleX = 0.001; // Process noise covariance for the accelerometer - Sw
const double Q_gyroX = 0.003; // Process noise covariance for the gyro - Sw
const double R_angleX = 0.03; // Measurement noise covariance - Sv
double angleX = 180; // The angle output from the Kalman filter
double biasX = 0; // The gyro bias calculated by the Kalman filter
double PX_00 = 0, PX_01 = 0, PX_10 = 0, PX_11 = 0;
double dtX, yX, SX;
double KX_0, KX_1;
double kalmanX(double newAngle, double newRate, double dtime) {
  // KasBot V2 - Kalman filter module - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1284738418
  // See also http://www.x-firm.com/?page_id=145
  // with slightly modifications by Kristian Lauszus
  // See http://academic.csuohio.edu/simond/courses/eec644/kalman.pdf and
  // http://www.cs.unc.edu/~welch/media/pdf/kalman_intro.pdf for more information
  dtX = dtime / 1000000; // Convert from microseconds to seconds
  // Discrete Kalman filter time update equations - Time Update ("Predict")
  // Update xhat - Project the state ahead
  angleX += dtX * (newRate - biasX);
  // Update estimation error covariance - Project the error covariance ahead
  PX_00 += -dtX * (PX_10 + PX_01) + Q_angleX * dtX;
  PX_01 += -dtX * PX_11;
  PX_10 += -dtX * PX_11;
  PX_11 += +Q_gyroX * dtX;
  // Discrete Kalman filter measurement update equations - Measurement Update ("Correct")
  // Calculate Kalman gain - Compute the Kalman gain
  SX = PX_00 + R_angleX;
  KX_0 = PX_00 / SX;
  KX_1 = PX_10 / SX;
  // Calculate angle and resting rate - Update estimate with measurement zk
  yX = newAngle - angleX;
  angleX += KX_0 * yX;
  biasX += KX_1 * yX;
  // Calculate estimation error covariance - Update the error covariance
  PX_00 -= KX_0 * PX_00;
  PX_01 -= KX_0 * PX_01;
  PX_10 -= KX_1 * PX_00;
  PX_11 -= KX_1 * PX_01;
  return angleX;
const double Q_angleY = 0.001; // Process noise covariance for the accelerometer - Sw
const double Q_gyroY = 0.003; // Process noise covariance for the gyro - Sw
const double R_angleY = 0.03; // Measurement noise covariance - Sv
double angleY = 180; // The angle output from the Kalman filter
double biasY = 0; // The gyro bias calculated by the Kalman filter
double PY_00 = 0, PY_01 = 0, PY_10 = 0, PY_11 = 0;
double dtY, yY, SY;
double KY_0, KY_1;
double kalmanY(double newAngle, double newRate, double dtime) {
  dtY = dtime / 1000000; // Convert from microseconds to seconds
  angleY += dtY * (newRate - biasY);
  PY_00 += -dtY * (PY_10 + PY_01) + Q_angleY * dtY;
  PY_01 += -dtY * PY_11;
  PY_10 += -dtY * PY_11;
  PY_11 += +Q_gyroY * dtY;
  SY = PY_00 + R_angleY;
  KY_0 = PY_00 / SY;
  KY_1 = PY_10 / SY;
  yY = newAngle - angleY;
  angleY += KY_0 * yY;
  biasY += KY_1 * yY;
  PY_00 -= KY_0 * PY_00;
  PY_01 -= KY_0 * PY_01;
  PY_10 -= KY_1 * PY_00;
  PY_11 -= KY_1 * PY_01;
  return angleY;
int readGyroX(void) {
  int data;
  data =gyro.g.x;
  return data;
int readGyroY(void) {
  int data;
  data = gyro.g.y;
  return data;
double getXangle() {
  double accXval = (double)readAccX()-zeroValue[0];
  double accZval = (double)readAccZ()-zeroValue[2];
  double angle = (atan2(accXval,accZval)+PI)*RAD_TO_DEG;
  return angle;
double getYangle() {
  double accYval = (double)readAccY()-zeroValue[1];
  double angle = (atan2(accYval,accZval)+PI)*RAD_TO_DEG;
  return angle;
int readAccX(void) {
  int data;
  data = compass.a.x;
  return data;
int readAccY(void) {
  int data;
  data = compass.a.y;
  return data;
int readAccZ(void) {
  int data;
  data =compass.a.z;
  return data;
  Wire.begin();
  if (!gyro.init())
    Serial.println("Failed to autodetect gyro type!");
    while (1);
  gyro.enableDefault();
   compass.init();
  compass.enableDefault();
    timer = micros();
  gyro.read();
 compass.read();
  double gyroXrate = (((double)readGyroX()-zeroValue[3])/14.375);
  gyroXangle += gyroXrate*((double)(micros()-timer)/1000000); // Without any filter
  double gyroYrate = -(((double)readGyroY()-zeroValue[4])/14.375);
  gyroYangle += gyroYrate*((double)(micros()-timer)/1000000); // Without any filter
  double accXangle = getXangle();
  double accYangle = getYangle();
  compAngleX = (0.93*(compAngleX+(gyroXrate*(double)(micros()-timer)/1000000)))+(0.07*accXangle);
  compAngleY = (0.93*(compAngleY+(gyroYrate*(double)(micros()-timer)/1000000)))+(0.07*accYangle);
  double xAngle = kalmanX(accXangle, gyroXrate, (double)(micros() - timer)); // calculate the angle using a Kalman filter
  double yAngle = kalmanY(accYangle, gyroYrate, (double)(micros() - timer)); // calculate the angle using a Kalman filter
  timer = micros();
  Serial.print("X: ");Serial.print(xAngle);Serial.print("\t");
  Serial.print("Y: ");Serial.print(yAngle);Serial.print("\t");
  Serial.print("\n");
  delay(10);
Could you please take a look of my source and tell me what I am doing wrong.I want to thank you in advance for your time.
Stanislav.
Logged
Denmark
Offline Offline
Full Member
View Profile
WWW
@stunito0o0
It looks like you are reading the magnetometer (compass) and not the accelerometer.
Btw the newest version of the code can be found here: https://github.com/TKJElectronics/KalmanFilter.
Logged
Offline Offline
Newbie
View Profile
@stunito0o0
Hi again, smiley
I thought too that it might be the compass data I am reading so i opened the example for the "LSM303.h" libraly and here is the source:
Code:
#include <Wire.h>
#include <LSM303.h>
LSM303 compass;
  Wire.begin();
  compass.init();
  compass.read();
  Serial.print("A ");
  Serial.print((int)compass.a.x);
  Serial.print(" Y: ");
  Serial.print((int)compass.a.y);
  Serial.print(" Z: ");
  Serial.print((int)compass.a.z);
  Serial.print(" M ");
  Serial.print((int)compass.m.x);
  Serial.print((int)compass.m.y);
  Serial.println((int)compass.m.z);
  delay(100);
According to the example  "compass.a.x","compass.a.y" and "compass.a.z" are for reading the acc data.I will really appreciate if you take another look of my code.I think that when i was customising your source i might have deleted something important.Thank you again for your time. smiley
P.S. Now i rememberd that i deleted part of the source for getting the data of acc and gyro.For example "readAccX" function  was something like this:
Code:
  int data;
  data = i2cRead(adxlAddress, 0x32);
  data |= i2cRead(adxlAddress,0x33)<<8;
  return data;
and i didn't understand what  "data |= i2cRead(adxlAddress,0x33)<<8;" is for so i deleted it.
now it looks like this:
Code:
  int data;
  data = compass.a.x;
  return data;
« Last Edit: March 14, 2013, 04:33:43 am by stunito0o0 » Logged
Denmark
Offline Offline
Full Member
View Profile
WWW
Sorry I was in a hurry when I wrote the first reply.
First of all I think it will be easier for you to if you modify this example: https://github.com/pololu/LSM303/blob/master/LSM303/examples/Serial/Serial.ino to your needs.
First of all you should NOT subtract the zeroValues, as they are specific for the IMU used in the example.
I think you can use your values directly, so you don't even have to subtract any zeroValue.
Take a look at this example: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/blob/master/IMU6DOF/MPU6050/MPU6050.ino
Also you assume that the gyro has the same sensitivity as the one used in the example which is most likely not the case (take a look at your datasheet)!
Logged
Pages: 1 ... 25 26 [27] 28 29 30   Go Up
Print
Jump to:
